AGodlyCanuck
- June 13, 2018
- Nelson, BC. Canada
- 1992 Explorer 4dr 4x4 XLT
So I whipped out my spark plugs and wires and thermostat to see if that would smooth out the slightly rough idle. Seemed to make a difference.
But there is still a bit of a studder in the idle.
Every 10ish or so seconds the rpms wiggle.
And you can feel a little shake in the vehicle.
Any ideas?
I've also got questions about the spark plugs I pulled out. What do you think of the condition?
I either need to replace the seals on the valves or the valve cover leak is leaking into the combustion chamber through the spark plugs.
Is that possible?
Any ideas?
Is that possible?
