Joe Dirt
- October 4, 2007
- 07 Camry
Best advice I've gotten: "If you have one of those variable thickness round gappers you may wear off the thin layer of platinum from the tip. You can and should gap platinum plugs, just do not apply pressure to the firing tip of the plug when adjusting the gap out."
I run Motorcraft DP's, and change them at max 50k. A spark plug is weaker each and every spark after the very first one. I haven't run Coppers, but mainly because I just wanted what was in there OEM because they just work so well..
