Spark Plug issue (must-read)
dothedeww
West Friendship, MD
2006 Explorer XLT
I have an 06 ex XLT with the 4.0 V6.
If you recall, I have been having major spark plug problems (fouling every 1000 miles). I replaced wires and everything, trying to figure out the problem. I replaced the stock plugs at 70000 because of poor gas mileage and stuff. I put in bosch platinums (matched up at parts store), and they fouled after 1000 miles. I then tried another brand (sorry, slipped my mind), and same thing happened. Then I went to NGK brand, same story. I went and gave in and got the motorcraft cheapo plugs to try them. They've been in 5000 miles with no signs of fouling.
Coincidence? Or can I just not put any aftermarket plugs in this explorer? If anyone has tried, please let me know.
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
We've always recommended Motorcraft platinum or double plats on the forum. Bosch, NGK, etc all seem to be really crappy on the trucks. Even the Allied Signal/Autollite seems to be better than the Bosch.
eXcali
Bourbonnais, IL
98 Explorer XLT AWD 5.0
i agree, Motorcraft is the best bet. However fouling after 1k miles is a bit outrageous. I would verify the gap on all the plugs and if it checks out I'd get it hooked up to a decent scanner that will map your fuel trims and O2 lvls. Something sounds very odd here.
If you don't have access to a good Scanner you can try resetting the computer. If the Gen 3's are the same as Gen 2 you just unhook the battery for 30 minutes. This should put it back into the learning mode.
dothedeww
West Friendship, MD
2006 Explorer XLT
Ya. I checked the scanner...reset the computer.
and autolite was the 2nd brand, just checked the 18 plugs i have laying on my work bench.
I just wanna know why the autolite/bosch/ngk are so much shorter than teh motorcraft....just realized that.
and finally, i guess I may have spoke too soon.
Pulled the motorcrafts just now...
cylinder 2's gap was knocked down to 024...was at 056 when I put it in. cylinder 1, 3 and 5 all had the white part, under the electrode (sorry for terminology) cracked down the side. The gap was fine though on 1,3,5. 4 and 6 seemed normal, just a little wear.
But all six have a black spot on them...like a burn mark. Plus, on the "l-thing that goes over the electrode, the thing you use to gap the plug", there looks to be a dirt like substance. There is also a little of the dirt like substance on the white thing below the electrode.
Any of these things something I should worry about.
The problem I was having with the other plugs was that the whole bottom of the plug was turning purplish-red...looked to be burning way too hot according to my haynes manual.
fixxxer
Aurora, Co.
93 XLT 4X4
Any pics of the plugs in question?
dothedeww
West Friendship, MD
2006 Explorer XLT
Camera is broke right now. As soon as I have access to a camera I will have pix up. Sorry.
dothedeww
West Friendship, MD
2006 Explorer XLT
And just to add to the one that had its gap knocked down. It was knocked down from the side it looked like. like the "l-shaped thing" looked like it had been slapped sideways.
dothedeww
West Friendship, MD
2006 Explorer XLT
finally...
Just wanted to say that around 4000 rpms i notice a crunching sound...kinda sounds like the intake is full of leaves....any ideas? could tihs be related?
nismotunedgtr
Windham, Maine
'93 XLT 250k miles
Pinging? Bad fuel pump? FPR?
dothedeww
West Friendship, MD
2006 Explorer XLT
that what I was tinhking. I just wanted to make sure it wasnt like a piston smacking on teh plug...since the gap was reduced to nothing when I pulled it....
shaker1
Algonquin, IL
2006 Explorer XLT 4X4 4.0
Sounds like you might be experiencing spark knock (detonation). Possibly running too lean. The ECU can only compensate so much. Check for unmetered air (leaks) and maybe get some electronics cleaner and spray the MAF. You might want to try putting the stock air filter back in. Oiled filters have been known to foul a MAF sensor causing false readings.
Also, a combination of a free flowing air filter and free flowing exhaust might require a custom tune to avoid running too lean. If detonation is wrecking your plugs, it could be damaging your motor (pistons, rings, valves, rods).
Also, carbon build up can create hot spots that produce pre-ignition and subsequently damage plugs and other critical components.
dothedeww
West Friendship, MD
2006 Explorer XLT
ya. I did clean teh MAF when i put the new intake in last week. And I checked for air leaks...none.
So I guess maybe look for a tune to see if its running to lean. Im just tearing through plugs...have to change plugs more often than oil.
And it bugs me that only 1 plug had the gap reduced to nothing. all the others just hada hairline crack in the ceramic. and im losing gas mileage if that means anything in this. 18 to about 16.
dothedeww
West Friendship, MD
2006 Explorer XLT
Sorry for so many posts..just wanted to post another thing I realized.
The thing has been smoking lately. Like after a long run...ill stop and see smoke coming from teh rear...towards the front. Also when getting on the gas...ill see smoke behind me. At first i thought it was dirt on the road...but its happening more and more.
Temp's are all fine...I ran with teh code reader on to monitor everything.
dothedeww
West Friendship, MD
2006 Explorer XLT
Tried to take pics today...none of them came out even close enough to clear to even see the plug.
But i pulled them today and theres a brown liquid on the bottom of each plug...smells like oil/gas. But it is the color of clean oil. Any ideas? Or is that normal?
shaker1
Algonquin, IL
To me it sounds like you are burning oil. Could be worn valve guide/seals or rings. This would explain the "brown liquid" and smoke. Smoke from burning oil tends to be bluish IIRC. Low compression might indicate worn rings.
Also, check your PCV system. You might get lucky and find a stuck PCV valve.
dothedeww
West Friendship, MD
2006 Explorer XLT
Would this be common for an engine with 76k on it?
And I have a "lifetime engine warranty" which specifies it is good on all gaskets and lubricated parts. Would this be covered?
shaker1
Algonquin, IL
Sounds like your warranty should cover this. It might be wise to remove your aftermarket parts (KKM), so they don't void your coverage.
No not common at all, particularly given your mileage.You really need to have this checked out professionally, my thoughts are only guesses.
dothedeww
West Friendship, MD
2006 Explorer XLT
Ya Ill definitly take off the kkm..even though i dont think personally it should void a warranty.
Titan08.5
98 explorer
Removing AfterMarket Parts
I read somewhere that a law was passed that a dealer can not void a warranty if the aftermarket part has no relation to the part that went defective. So it would be safe to say that any aftermarket part i.e. Bolt on parts, should not have any affect on the rings if they went bad. I would agree that it would be a ring or vaulves that go bad to cause this in cars. Smoke and brownish liquid on a plug would say that oil is getting down to the top of your pistons. I hope this helps.....
Explorer Junky
Grand Rapids, Mi
1997 XLT 4 dr 5.0
what about E-3's?? I just bought some and have yet to put them on!! Should I or no??
F 06-07 V8 Spark Plug Issue - Change Them Early? Stock 2006 -2010 Explorers 119
G Water in Spark Plug Well (#8) Stock 2006 -2010 Explorers 4
B Radiator Fluid Leaking From Above Spark Plug Cap *Video* Stock 2006 -2010 Explorers 6
L Spark plug replace 2010 Mountaineer 4.0 Stock 2006 -2010 Explorers 2
S Infamous water in the spark plug wells Stock 2006 -2010 Explorers 2
W Spark Plug lasted 30 days Stock 2006 -2010 Explorers 5
D Correct Spark Plug Type Stock 2006 -2010 Explorers 0
J 06 Explorer 4.6 3V,need tap specs for spark plug Stock 2006 -2010 Explorers 36
R My Spark Plug Change - 2006 EB 4.6L V8 Stock 2006 -2010 Explorers 7
P Water In Spark Plug Well Solution Stock 2006 -2010 Explorers 0
Mitchs07explorer Spark plug questions on V6 Stock 2006 -2010 Explorers 10
M 2nd choice spark plug Stock 2006 -2010 Explorers 6
R spark Plug removal Stock 2006 -2010 Explorers 18
E spark plug and coil question Stock 2006 -2010 Explorers 4
V Spark Plug Removal Experience - 2006-2010 4.0L V6 Stock 2006 -2010 Explorers 3
9 Stripped spark plug hole Stock 2006 -2010 Explorers 4
R Transmission shudder and spark plug fix Stock 2006 -2010 Explorers 1
E 4.0 SOHC Spark plug cables Stock 2006 -2010 Explorers 3
B Spark Plug clarification for V8 Stock 2006 -2010 Explorers 5
P Running rough after spark plug and wire change. Stock 2006 -2010 Explorers 27
E A quick question about spark plug for the experienced Stock 2006 -2010 Explorers 11
B Another spark plug questions thread! Stock 2006 -2010 Explorers 15
E Spark plug wires ohm values Stock 2006 -2010 Explorers 4
E Spark plug wires Stock 2006 -2010 Explorers 11
R Unusual Spark Plug Question Stock 2006 -2010 Explorers 4
C The spark-plug dead horse... Stock 2006 -2010 Explorers 4
C Weird Spark Plug Break - not the usual kind Stock 2006 -2010 Explorers 9
W spark plug question Stock 2006 -2010 Explorers 3
B Age old spark plug question Stock 2006 -2010 Explorers 4
E Anybody uses SP498 spark plug? Stock 2006 -2010 Explorers 4
L Broken facet on a spark plug Stock 2006 -2010 Explorers 20
B Proper spark plug for a 2006 V8? Stock 2006 -2010 Explorers 14
M Champion 7989 Spark Plug Stock 2006 -2010 Explorers 24
J #4 missfire and iridium spark plug question Stock 2006 -2010 Explorers 3
M 4.6l 3v Broken Spark Plug Removal Method Stock 2006 -2010 Explorers 2
M 4.6l 3v Spark Plug Removal Instructions Stock 2006 -2010 Explorers 15
Z 06 v6 spark plug change and trans fluid change Stock 2006 -2010 Explorers 1
9 V6 spark plug change? Stock 2006 -2010 Explorers 3
M Spark plug stuck Stock 2006 -2010 Explorers 5
F Champion 7989 Spark Plug Failed Stock 2006 -2010 Explorers 3
S Spark Plug Removal Video: The Ford TSB Way Stock 2006 -2010 Explorers 10
P Spark Plug Stock 2006 -2010 Explorers 12
S 4.6L spark plug problems Stock 2006 -2010 Explorers 15
M Quick spark plug ?? Stock 2006 -2010 Explorers 4
Z Starting my spark plug replacement project Stock 2006 -2010 Explorers 8
O My Spark Plug Endeavor Stock 2006 -2010 Explorers 23
J Spark Plug Diagram? Stock 2006 -2010 Explorers 2
C 2006 spark plug boots Stock 2006 -2010 Explorers 2
D Ford triton V8 spark plug removal question Stock 2006 -2010 Explorers 3
P Any fix for water in spark plug wells 4.6L? Stock 2006 -2010 Explorers 39
Similar threads
