Spark Plug Question | Ford Explorer - Ford Ranger Forums - Serious Explorations
Spark Plug Question
djleatherb15
New Hampshire
1992 Ford Explorer XLT
Hello, I just bought some Denso PK16TT spark plugs and I gapped them at 0.054 but the plugs are gapped at 0.040 is it okay that I gapped them? Are these plugs good or not?
Wolfie_85
Iowa
1994 Ford Explorer XLT
You got the gap right. I've never used those, so all I can say is try 'em. These don't really need extravagant plugs, platinum Autolites or Motorcrafts are what I use. Copper is ok, too.
djleatherb15
New Hampshire
Turns out the ones that I got don't need to be gapped as they are already gapped when they leave the factory. Now I get to take them all out again and regap them to factory settings.
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
NEVER follow that "pre gapped" BS. Other engines using the same plug have different gaps. A bump on the snout changes gaps too.
2stroke
Location
55302
Annandale, MN
1993 Ford Explorer Sport
I gap every plug, and always have. I have never once trusted pre-gapped plugs. I think .054-.056 is the gap range, but I could be wrong.
natenkiki2004
Blue Bomb!
Location
North Idaho
1991 & 1994 Explorers
Gapping is good but on the platinum ones, be careful, you need to use the proper tool to adjust the gap and not pry on the platinum tips.
2stroke
Location
55302
Annandale, MN
I never knew that, but then again I've never bought a platinum plug before. I run standard plugs without issue in every engine I own. Its good to learn new things. Can you still tap them to close the gap on platinum's?
natenkiki2004
Blue Bomb!
Location
North Idaho
Yea, that's fine, you just don't get a good amount of control that way. A lot of people will say that you can't gap them but it's BS. Just be gentle and don't try to jam/wedge something against the platinum spots.
