Spark Plug Removal Video: The Ford TSB Way
stkelly
Laytonsville, MD
'08 Mountaineer
I just made a how to video demonstrating the Ford TSB way to remove the spark plugs on the 4.6L 3V. I went 8 for 8!
Here's the link, please feel free to give me any comments.
You all have been a great help to me, so any way to give back.
killer.jensen
Salina, Utah
1993 Exp.
Where's your safety glasses when using the compressed air?
stkelly
Laytonsville, MD
'08 Mountaineer
Didn't even think to put them on. Good safety point for next time.
I added a note to the video.
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
mgmgmg
Plymouth, MN
'94 LTD '10 LTD V8
Does this apply to a 2010 explorer? Or is it a differnet style?
stkelly
Laytonsville, MD
'08 Mountaineer
I don't think the 2010's have this problem. It's only an issue from 06 to late production year 07 (11/30/2007) for 08 models. This is what's stated in the Ford TSB.
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
mes882
iowa
2007 mountaineer prem
I just did mine today. I went the tsb way. I also went 8 for 8. Now what to do with lisle tool.
t0ked
NYC
2006 Explorer V8 AWD
I'm dreading doing this but I know at 92k miles, I'll need to do it soon. Thanks so much with the video. It will definitely come in handy.
mes882, If you would like to pay it forward and help a guy out with the lisle tools, I will promise to do the same.
mes882
iowa
I was dreading doing it as well. I did have to turn mine in and out a few times. I also turn it out until it got hard then turn it back in let it sit 5 minutes or so let the carb cleaner work then back out. I used sea foam deep clean since I couldn't get the ford stuff.
Sorry tOked cant give it away. As of now I am thinking I am going to keep until I sell my mountaineer. That way I have it just in case. You can get it at amazon for 65 shipped.
R spark Plug removal Stock 2006 -2010 Explorers 18
V Spark Plug Removal Experience - 2006-2010 4.0L V6 Stock 2006 -2010 Explorers 3
M 4.6l 3v Broken Spark Plug Removal Method Stock 2006 -2010 Explorers 2
M 4.6l 3v Spark Plug Removal Instructions Stock 2006 -2010 Explorers 15
D Ford triton V8 spark plug removal question Stock 2006 -2010 Explorers 3
B Early 3 valve V-8 Spark Plug Removal Stock 2006 -2010 Explorers 12
G Water in Spark Plug Well (#8) Stock 2006 -2010 Explorers 4
B Radiator Fluid Leaking From Above Spark Plug Cap *Video* Stock 2006 -2010 Explorers 6
L Spark plug replace 2010 Mountaineer 4.0 Stock 2006 -2010 Explorers 2
S Infamous water in the spark plug wells Stock 2006 -2010 Explorers 2
W Spark Plug lasted 30 days Stock 2006 -2010 Explorers 5
D Correct Spark Plug Type Stock 2006 -2010 Explorers 0
J 06 Explorer 4.6 3V,need tap specs for spark plug Stock 2006 -2010 Explorers 36
R My Spark Plug Change - 2006 EB 4.6L V8 Stock 2006 -2010 Explorers 7
P Water In Spark Plug Well Solution Stock 2006 -2010 Explorers 0
Mitchs07explorer Spark plug questions on V6 Stock 2006 -2010 Explorers 10
M 2nd choice spark plug Stock 2006 -2010 Explorers 6
E spark plug and coil question Stock 2006 -2010 Explorers 4
9 Stripped spark plug hole Stock 2006 -2010 Explorers 4
R Transmission shudder and spark plug fix Stock 2006 -2010 Explorers 1
E 4.0 SOHC Spark plug cables Stock 2006 -2010 Explorers 3
B Spark Plug clarification for V8 Stock 2006 -2010 Explorers 5
P Running rough after spark plug and wire change. Stock 2006 -2010 Explorers 27
E A quick question about spark plug for the experienced Stock 2006 -2010 Explorers 11
B Another spark plug questions thread! Stock 2006 -2010 Explorers 15
E Spark plug wires ohm values Stock 2006 -2010 Explorers 4
E Spark plug wires Stock 2006 -2010 Explorers 11
R Unusual Spark Plug Question Stock 2006 -2010 Explorers 4
C The spark-plug dead horse... Stock 2006 -2010 Explorers 4
C Weird Spark Plug Break - not the usual kind Stock 2006 -2010 Explorers 9
W spark plug question Stock 2006 -2010 Explorers 3
B Age old spark plug question Stock 2006 -2010 Explorers 4
E Anybody uses SP498 spark plug? Stock 2006 -2010 Explorers 4
L Broken facet on a spark plug Stock 2006 -2010 Explorers 20
B Proper spark plug for a 2006 V8? Stock 2006 -2010 Explorers 14
M Champion 7989 Spark Plug Stock 2006 -2010 Explorers 24
J #4 missfire and iridium spark plug question Stock 2006 -2010 Explorers 3
Z 06 v6 spark plug change and trans fluid change Stock 2006 -2010 Explorers 1
9 V6 spark plug change? Stock 2006 -2010 Explorers 3
M Spark plug stuck Stock 2006 -2010 Explorers 5
F Champion 7989 Spark Plug Failed Stock 2006 -2010 Explorers 3
P Spark Plug Stock 2006 -2010 Explorers 12
S 4.6L spark plug problems Stock 2006 -2010 Explorers 15
M Quick spark plug ?? Stock 2006 -2010 Explorers 4
Z Starting my spark plug replacement project Stock 2006 -2010 Explorers 8
O My Spark Plug Endeavor Stock 2006 -2010 Explorers 23
J Spark Plug Diagram? Stock 2006 -2010 Explorers 2
C 2006 spark plug boots Stock 2006 -2010 Explorers 2
P Any fix for water in spark plug wells 4.6L? Stock 2006 -2010 Explorers 39
F 06-07 V8 Spark Plug Issue - Change Them Early? Stock 2006 -2010 Explorers 119
Similar threads
