aldive
Elite In Memoriam
- January 17, 2001
- 1999 XLT
It’s been 79.5k miles since I last changed the spark plugs on my 1999 4.0 SOHC.
Prior to starting the job, I recommend gathering all the tools that will be needed as well as the plugs and wires. I would never change the plugs without changing the wires ( unless using Magnecor wires ).
The first step was to jack up the truck and place it on jack stands. This was followed by removing the inner fender rubber skirts. There was no reason to remove the entire finder liner. Nothing else was removed or moved.
Always change the plugs on a cold engine.
I decided to do the most difficult passenger side first. This in reality was trouble-free; it only took about 20 minutes. The spark plug wires were removed with a spark plug boot tool. New Motorcraft SP500 AGSF22FM spark plugs (http://www.motorcraft.com/products.do?item=18 ) were gapped to 0.065” instead of 0.054” ( to take advantage of my Screamin' Deamon coil pack (http://www.explorerforum.com/forums/showthread.php?p=1535138#post1535138 ).
Dielectric grease (http://www.permatex.com/products/au...auto_Permatex_Dielectric_Tune-Up_Grease_1.htm ) was applied to the spark plug wire ends and
anti-seize compound (http://www.permatex.com/products/au...ubricants/Permatex_Anti-Seize_Lubricant_a.htm ) was applied to the spark plug threads. The only problem encountered on the passenger’s side was with the new Magnecor spark plug wires; each one was about 4 inches too short. I have e mailed Magnecor about this problem.
The driver’s side was the easiest. The only tools needed were a 3/8’ ratchet, a 5/8” spark plug socket, a 1” and a 3” extension as well as a swivel. All plugs were accessed through the wheel well. Plug number 4 ( the plug closest to the front ) is somewhat tricky due to the lower EGR tube. This side also took 15 minutes. The plugs and wires were treated the same as the passenger’s side. The wires were a perfect fit on this side.
All 6 old plugs had a 0.055” gap ( they were gapped at 0.054 when new ) and were in great condition. There was virtually no wear ( the old plugs were Motorcraft double platinum ). This was with 80k miles on them. They could have easily gone another 20k or more miles.
No first aid for cuts and scrapes was need since there were none. No editing out swear words was needed.
The ease of this job was due in part to the use of anti-seize and dielectric grease on the old plugs and wires.
After buttoning everything up, a turn of the key instantaneously established the job was successful. A brief ( 5 mile ) road test confirmed.
A gas mileage assessment will be conducted during a 1500 mile road trip this weekend. The first 500 miles will be with the 0.065” gap and the remaining portion of the trip will be with stock ( 0.054” ) gap on new plugs. Details will be reported on my return.
