Spark Plug Wires & Plugs | Ford Explorer - Ford Ranger Forums - Serious Explorations
TomCat_Ford
98 Explorer
So I'm looking to replace the spark plug wires and spark plugs on my '98 SOHC. Are there any recommendations for quality plug wires that won't break the bank? What should I look for when ordering plug wires?
Also... how are those E3 style plugs compared to the conventional spark plugs? Are they really that much better?
Thanks.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
This is a controversial subject with numerous opinions. You could stick with Motorcraft or Autolite plugs if you want to keep it stock. There are so many options like copper, platinum, iridium, etc to choose from.
96eb96
Albany, NY
96 EB V6 OHV 4WD
Thanks.
Motorcraft plugs and wires are the best choice, Autolite second best. Rockauto has good prices on wires, and you can find 5% discounts on the web, also autozone sells M/C plugs. This is the consensus on most Ford and Lincoln sites. Fancy plugs don't seem to work well in these cars, but you are welcome to try and report back!
hazmat456
tomah wi
1997 mercury mountaineer
BrooklynBay
Staff member
Moderator
Brooklyn, NY
marragtop
balt, md
91, 92, 95, and 2000 xlts
I agree on Motorcraft and best way to get to the plugs is thru the wheel wells. Don't forget to put anti-seize on the new plugs.
mikepier
Long Island, NY
99 XLT
15 XL
I agree with the Motorcraft. I put in Autolites plugs about a year ago, they are not bad but I think they are the cause of my "vibrating" idle. Its not enough of a problem for me to change them out.
Also stick with Motorcraft wires.
Ranger Al
Fresno, California
'00 FX4 Ranger
The guys are right, fancy plugs doesn't work on these engine. Learned the hard way.
ornithology
Vancouver, BC
'03 X Sport2dr 4.0 V6 XLT
... and dielectric grease on the boots as well.
What is dielectric grease?
And did you notice any increase in performance or mpg?
Just went through a rough winter and wanting to change my plugs and oil.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
ornithology
Vancouver, BC
Awesome thanks!
That guy should pull up his sleeves though lol.
Gotta get me a tube of that grease...
Ray Lobato
Moderator
Moderator Emeritus
2006 Honda Accord
If your plug wires are pretty old, they will degrade performance over time. Not much but some. When you replace the wires and plugs, performance will increase back to normal, but they will not increase performance past what you originally had to begin with. Any increase in resistance from the coil pack to the spark plug will decrease performance, by decreasing the amount of spark. Having plug wires with the least amount of resistance is good.
sleepergt98
long island, ny
'98 mounty
eh...was just researching this to replace plugs in my '98 5.0 but....doesn't m/c = autolite?
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
FYI Autolite and Motocraft plugs are the same plugs
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
For me, on a bone-stock 98 SOHC, Motorcrafts were good enough for the first 100,000 miles. So far, they're good for the first 70,000 miles of the second 100k. If it lasts that long, I'll be installing them for the third 100,000 miles. I doubt I'll need a 4th set... :(
-Joe
The Captain
Santa Cruz CA
2014 Ford Explorer PI
So happeneds I noticed this thread about the E3 plugs. Well I installed them with the JBA Wires. Motor seemed to run awesome* after they were installed.
Strange stuff started to happen as I was driving to break things in. The motor was getting hotter than usual and seemed to have the "virbrating Idle" during stop lights. Plus the Check Engine light was flashing under load (up hills). Not sure what that was all about but I'm going tink with it some more.
I think the E3 Plugs run to hot for the 5.0L or something.
I've owned a 92' 4WD V6 OHV and installed motorcraft plugs. Ran like a champ.
How are Bosch +4 Platinums?
