Spark Plugs!!! | Ford Explorer - Ford Ranger Forums - Serious Explorations
Spark Plugs!!!
tylergabriel
Oregon City, Oregon
'94 XLT Explorer
Hey everyone! I have a 1994 Exploder Xlt 4.0 ltr automatic. I wanted to replace my spark plugs yesterday (after inspecting one I noticed they are in pretty bad shape!) however my Haynes manual does not really show you the process of changing all 6 plugs and all 6 wires on a 4.0 litre. My friend I looked at the plugs the lineup of were they are is very difficult I think I need to remove a bounch of parts to access most of them. CAN ANYBODY HELP??? pictures would be ****!
marragtop
balt, md
91, 92, 95, and 2000 xlts
Get to them through the wheel wells. There are many on this in the forum.
Hucks52786
Goose Creek, S.C.
'94 XLT
It's not easy but with a few extensions and a universal joint you can get them all. Going through the wheel well will make the back ones soooo much easier. You shouldn't have to remove anything.
MrQ
Smokey the clutch is; Missed shift you did
Moderator Emeritus
Location
Humid, Damp, and Hot
Houston, TX
'98 EB, '93 Limited
Check the thread in my sig.
marragtop
balt, md
The only thing you may have to remove is some skin from your knuckles...!!
loner4u69
Forest Grove, Oregon
91 XLT
Its alot easier with a body lift lol
john93rangerstx
warwick ri
93 rangers stx
I DID IT ON MY 93 RANGER AND IS WAS NOT THAT BAD THE HARD ONE IS ON THE PASAGER SIDE BACK BUT JUST DONT USE A extension AND THE RACHET AND SOCKET WILL JUST FIT IN THERE
arco777
1994 Explorer 2dr 4x4
Replacing plugs and wires isn't too bad. I have never gone through the fenderwells but I hear it's easier. Pulling the boots off is the only part I hate because when they come off my knuckles bounce off metal parts and leave skin behind. The wires are easy to replace, there's plenty of room to reach around the back of the intake and unclip them. Make sure when you put the new ones in to keep them routed through the same clips and off of hot components.
If replacing plugs and wires at the same time, a few tips.
Replace one plug and one wire at a time so you don't mix up the order. For best results gap the plugs properly (I think .056 to .062, but check the sticker near your fan to be sure), then put some anti-seize compound on the threads before screwing them in. You can use a short piece of rubber hose to thread them in hard to reach areas - slip it over the tip and thread plugs in with it, it won't strip the metal that way if you crossthread. Run the plugs in snug but don't reef on them, too much torque can break things. Put silicone dielectric compound on the metal tips. Push the boot all they way on, wiggle it and tug on it gently to be sure it's seated.
Don't use the Bosch plugs, they don't provide any performance gains (I have tried them twice) and are unnecessarily expensive... try Motorcraft platinums or even Autolites. For wires, the Bosch premiums are not that great either, I had a brand new one where the connector was loose on the wire inside the boot and it made poor contact.
Good luck!
dect
Jalisco
ranger 2wd sup 98 xlt
Go trough the wheel well , remove the wheel , the mud skirt , and from there you can change the 3 passenger side spark plugs within 20 minutes.
