original91
- September 19, 2008
- Los Angeles
- 91 Eddie Bauer Red 4x4
After replacing two speedo gears, I realized two things about my 91 Eddie Bauer 4x4 when the speedometer no longer worked...one, overdrive don't work as well, and two, the gears in the housing were the culprit not the easy one that I replaced on the end of the speedo cable( darn crap shoot SOB).
All I can do is put my finger in speedo cable hole and feel where the gears in the housing are sort of scalloped out and have a Homer Simpson epiphany DOCH! while wishing I could slap silly the engineer that designed it. And I thought it was the easy fix! Hah!!! gear on the end of the cable my eye...NOT(POS design).
OK so how much of a mess is it to remove the housing where the rear drive shaft hooks up and change that stupid plastic internal gear?...I'd like to use my overdrive, my gas mileage is bad enough. Or do I want to know?
Thanks
Thanks
