Speedometer - ABS - Odometer Problem
dx650sc
Haverhill, MA
'98 Sport
Help! My speedometer does not function. It will kick on RARELY. Whenever the speedometer is not working, the odometer does not work either. My ABS light comes on frequently, usually right after the ABS kicks in for no reason (making stop time a little longer :().
I have replaced the rear ABS Speed Sensor located in the rear differential. This did not cure the problem as I thought it would. I am very stuck and need my speedometer back.
Any help would be GREATLY appreciated! THANKS!
4 Speedometer/tach/abs light radio Stock 1995 - 2001 Explorers 3
M Speedometer/ABS problem Stock 1995 - 2001 Explorers 0
K 01 Explorer Sport - ABS and Speedometer not working, VSS replaced Stock 1995 - 2001 Explorers 0
D Abs light on no speedometer no cruise Stock 1995 - 2001 Explorers 2
D Dash lights speedometer abs Stock 1995 - 2001 Explorers 0
M ABS light on Speedometer erratic Stock 1995 - 2001 Explorers 6
I pull fuse for abs no speedometer Stock 1995 - 2001 Explorers 0
J Wont shift,no speedometer,and ABS remains ON Stock 1995 - 2001 Explorers 1
E Speed Sensor/Abs light/ Speedometer Stock 1995 - 2001 Explorers 2
B 2000 Mountaineer speedometer issues Stock 1995 - 2001 Explorers 4
S Speed sensor fault - Speedometer works Stock 1995 - 2001 Explorers 1
O Weird Odometer/Speedometer Issue Stock 1995 - 2001 Explorers 4
H Speedometer Not Working Stock 1995 - 2001 Explorers 1
Mbrooks420 Speedometer flaky 1998 5.0 Stock 1995 - 2001 Explorers 6
F Speedometer lights not working Stock 1995 - 2001 Explorers 3
P Speedometer shows more than actual Stock 1995 - 2001 Explorers 0
G Gremlins in Speedometer/Odometer Stock 1995 - 2001 Explorers 6
L speedometer work/stop/works Stock 1995 - 2001 Explorers 4
Z Speedometer program? Stock 1995 - 2001 Explorers 2
L speedometer Stock 1995 - 2001 Explorers 3
G fuse 25... gem and speedometer 1996 explorer xlt Stock 1995 - 2001 Explorers 2
J Speedometer not working or od Stock 1995 - 2001 Explorers 1
D Speedometer Stock 1995 - 2001 Explorers 3
E 96 Ford explorer speedometer not working Stock 1995 - 2001 Explorers 13
J Speedometer stuck at 50 Stock 1995 - 2001 Explorers 0
M Speedometer Works But Odometer Does Not Stock 1995 - 2001 Explorers 0
E Speedometer WAY off! Stock 1995 - 2001 Explorers 1
S Speedometer is off by 20km/hr (12mph) Stock 1995 - 2001 Explorers 2
C 97 Limited speedometer issues Stock 1995 - 2001 Explorers 0
C Speedometer/odometer trouble Help!? Stock 1995 - 2001 Explorers 0
T Issues fixed and Speedometer issue remains Stock 1995 - 2001 Explorers 0
J 2000 limited speedometer problem Stock 1995 - 2001 Explorers 1
F Speedometer Issues Stock 1995 - 2001 Explorers 0
B Speedometer out of whack Stock 1995 - 2001 Explorers 2
B 98 Ford Explorer XLT AWD 5.0 speedometer Stock 1995 - 2001 Explorers 4
M How to change speedometer for different axle ratio Stock 1995 - 2001 Explorers 4
J Speedometer hangs at 50mph once warm Stock 1995 - 2001 Explorers 2
R Flittering speedometer Stock 1995 - 2001 Explorers 2
A Speedometer, Windshield Wipers, and Dome light stopped working Stock 1995 - 2001 Explorers 4
W Jumping Speedometer Stock 1995 - 2001 Explorers 0
P The speedometer needle is jumping. Stock 1995 - 2001 Explorers 8
T 96 Exp LTD odometer & speedometer don't work Stock 1995 - 2001 Explorers 13
D Speedometer Issues Stock 1995 - 2001 Explorers 3
B Speedometer Inaccurate on '03 Sport Stock 1995 - 2001 Explorers 3
D 1998 explorer speedometer not working Stock 1995 - 2001 Explorers 0
D speedometer ,odometer,tachometer not working Stock 1995 - 2001 Explorers 1
S 1995 Explorer XLT - Speedometer Problems Stock 1995 - 2001 Explorers 3
bronchole speedometer not working - Need a schematic Stock 1995 - 2001 Explorers 2
Z No speedometer, CEL, VSS code, and I'm at a loss... Stock 1995 - 2001 Explorers 5
H 98 Speedometer intermittent bouncing, OD out, Cruise out no lights/codes Stock 1995 - 2001 Explorers 11
Similar threads
