bronchole
Driveway flexing!
- May 13, 2009
- Los Angeles, CA
- 1997 Monsterneer
- Callsign
- KI6MCO
So my speedometer is off on my Mounty. It has the tranfer case mounted VSS with the gear on the tip. The problem is that in order to correct the speedometer/odometer I need a 22 tooth gear for it. They don't make a 22 tooth gear. They make a 21 tooth and a 23 tooth.
So I am considering looking in to a re-calibraction module that will go in line with the output for the VSS to correct my readings. What units are available?
