Dmg1ndun
- September 17, 2014
- San Diego,ca.
- 2000 ford explorer 2wd
My speedometer,odometer and tach. Stop functioning the other day.
Cel came on code was for a vss malfuncition. Replaced the sensor and nothing
Happend. I also checked fuses and all seem ok.. day prior I had a after market radio
Installed and and next morning is when I noticed the meters stopped working.I did buy wiring harness so no wires needed to be cut. But ther was one a gray and blk strip wire.
Seperate from the rest that plugged into stock radio the was assumed a ground wire
And was connected to ground wire. I'm starting to think its not ground...anyone one know
What that wire is or what I should do...thanks
