Jun Sunga
- January 29, 2019
- Location
- Qatar (Middle East)
- 2009, Sport Trac Ltd
Hi, I'm working at a Middle Eastern country called Qatar, but I visit Arkansas almost every year (Heber Springs & Conway).
I love my Sport Trac 2009!
I have replaced my turn signal lamps into LED and are working well.
However, the dashboard keeps showing that the turn signal lamps are dead - which is incorrect.
After some web research I learned that the Turn Signal Flasher needs to be replaced by a LED version flasher because the new LED lamps can not be detected due to lower voltage requirements.
So I purchased an LED Turn Signal Flasher from Amazon to replace the stock flasher - one that does not require installing resistors at the lamps.
I tried two times but I can't locate the flasher under the dashboard/steering column.
From the web I have seen location photos and diagrams for 2003, 2005 and 2007 models - but can't find any for 2009 model.
Can anyone send me photos or a clear diagram of the location of the Turn Signal Flasher?
A short videoclip on locating it will be even better.
Many thanks!
Many thanks!
