Jerry R
- May 12, 2017
- Wallingford
- 2003 Explorer Sport Tr
2003 Sports trac xlt.
I'm going dark?
So what i'm trying to figure a few things with my Sports trac.
So my headlight switch doesn't seem to do anything, if the switch is off the lights are still on, if i switch to running lights or headlights nothings seems to change, is this normal? There is no backlight for these? Are there bulbs to replace?
Next question - fan control, mode, hot\cold control dial cluster > no backlight? should there be one? Are there bulbs to replace?
Next Dash cluster only lights up for battery/temp, no dodo/speedometer fuel gauges are not lit up? I'm in the dark? Are there bulbs to replace?
2x4, 4x4 switch lit up fine.
Rear bed window up/down switch not lit up? Should it be? Are there bulbs to replace?
Mirror switch should be lit up?
Everything seems to work, just not lit up? Are there bulbs to replace?
I'm going dark?
