moonman85
- August 6, 2014
- northern mn
- 1993 xlt
- Callsign
- N0SKS
Hello I have a question about what spring buckets to use for a sas on my 93 explorer. I see most people are using aftermarket it seems but cant you just use the stock ones and bend the tabs for the early bronco springs to fit? is there a problem with just using them that im not aware of? to my understanding is if you use stock spring buckets with 3.5 eb springs you will end up around 5.5-6 inches of lift. please explain the pros and cons of both please.
Thanks kevin
Thanks kevin
