QuesoGiraffe
- August 10, 2018
- Pennsylvania
- 2004 Explorer Limited AWD
Hi ExplorerForum,
I was finally able to put my BTF spacers and UCAs a few weeks ago. I've been anxious to get this done and replace my struts, but was helping my Dad swap a new engine into his 2013 Escape. I followed bampq6's excellent writeup here
How To: BTF-Fabrication Spacer Lift Install
and perused a few other posts as well. I ending up ordering new KYB strut assemblies from Rock Auto as well
Part #4SR4082SR4051
The lift finally went together after a whole weekend of work, lots of penetrating fluid, and quite a few bolt heads snapped off and stuck bushings. I opted for the highest leveling kit I could get, and ended up with a squat of almost 2" higher in the front. I was hoping this was partially due to alignment issue, but after getting an alignment, the squat was still there. After a few weeks of driving, it's settled out to about an 1 1/2" squat. I talked to Brandon from BTF Fan about a week ago to confirm the spacer dimensions, with the fronts being about 2" and the rears being about 1 1/2". This matches what I have in the Explorer, though Brandon did say a squat of maybe 1/2" is normal, depending on the engine. Unfortunately, I don't have any measurements pre lift, but some measurements post lift are
Front cross member ground clearance 14 3/4"
Rear differential ground clearance 11 1/2"
Centerline of front hub to fender opening 23 1/4"
Centerline of rear hub to fender opening 21 3/4"
I'm running Falken Wildpeak AT3Ws in a 265/70 R17 for reference.
Brandon offered to make me a set of 1 1/2" front spacers, which I'll pay for if I have no other option, but I figured I'd try here before spending that money (and having to get another alignment.)
I don't remember any squat before the lift, but I am running a matching a full size spare, and carry some essential fluids and whatnot in the trunk. After climbing under the vehicle, I did notice that the alignment shop hadn't touched the rear toe link. I could see that preventing the spring from extending all the way, but would think that would affect the toe as well. I still have the stock length sway bars, but am planning on following a similar process from what is discussed here
www.explorerforum.com
I can't imagine the sway bar is keeping the springs compressed though. haven't had a chance to compare the lengths of the strut assemblies to KYB's specifications, but they looked identical in size and shape to the old ones, but that's a possible avenue I can look into this weekend as well. Attached is a picture of my Explorer post lift, but I don't think it does it justice I'm really not into the squatted look Does anyone have any experience or recommendations for this sort of thing? Any help is greatly appreciated.
2004 FORD EXPLORER 4.0L V6 Suspension Kit | RockAuto
RockAuto ships auto parts and body parts from over 300 manufacturers to customers' doors worldwide, all at warehouse prices. Easy to use parts catalog.
www.rockauto.com
Part #4SR4082SR4051
2nd Gen "Custom" Anti Sway Bar Links, Cheap!
After I installed my used Superlift, I needed front sway bar links. None were available locally, and the Superlift parts were expensive. My stockers were rusted solid, I had to hacksaw them off, so I had no choice but to make some. Parts List: 2 pieces appropriate length of 3/8"...
