Squeaky Brakes......Again 2011 Ex
Smoktya
Bethlehem, PA
2011 4WD XLT
Hi all,
We had the TSB completed for the "small movement squeaky brakes" issue (like moving up a little at a stop light) about 5 months ago. Well, now it is back and in full effect. I am taking my car in tomorrow to have quite a few things completed (inspection, MFT update (no thumb drive for me), cooling fan fix and of course the "squeaky brakes" syndrome. Hopefully this time they will just replace the rotors instead of re-surfacing them because whatever they did the first time didn't totally fix the issue. Wish me luck:)
1995E
Maryland
95 + 11 Ex both XLT
Yeah, resurfacing them ruins your rotors and shortens the lifespan of the rotors. I had the squeaky brakes when going in reverse a long time ago. I think it takes a while and then it just gets better. I think people (me among them) were a bit **** about the whole squeaky brake issue. I heard squeaks a long time ago but now I don't hear them at all. Could be because it was the warm temperature but I think it just happens. What I used to do if I heard it, I used to just go on the highway and hold the brakes and then hold it hard for a while when slowing down to the exit and the noise goes away.
GWA1
New Castle, DE
2011 Explorer Limited AWD
Hi all,
I had the same symptoms. Had the TSB done well over six months ago. Haven't heard them since. I'm guessing your dealer either didn't replace pads with updated ones or did not use enough brake grease when reassembling. Just my two cents! Only had about 2000 + miles on the Ex so they did not cut rotors. Haven't heard of anyone having the squeak come back.
Smoktya
Bethlehem, PA
2011 4WD XLT
update.....my vehicle is in the shop and they tell me that it is normal for your car to have some sort of squeaky brakes from time to time. I told them that I didn't spend this much money for my vehicle to have squeaky brakes. They wanted to charge me $95 to put some grease or something on the components and i said you're crazy. The only time they squeak is when it comes to a slow stop or crawl, and there is a TSB out for this, plus it isn't even 1 year old yet....Unbelievable. I told them to look up the TSB again (it was already completed on my car) and to call me back. I don't think i will ever deal with them again. They also told me that i need to bring in my USB stick since they don't complete MFT updates without it. i called Ford Vehicle support and they set the dealership straight. I think some better training needs to be done because i can't believe that i know more about this stuff than they do.
harlenm
Shelton, CT
2013 Limited(lemon swap)
My brakes squeak like crazy after having the fix done. I'm just gonna buy some new pads one of these days and have them changed.
Smoktya
Bethlehem, PA
2011 4WD XLT
after getting the car back, they told me that they replaced the rotors (instead of machining them last time) and the pads, along with a few other misc brake components. Hopefully, this will stop the squeaks for good. As for the new MFT, i like it a lot. Seems to be a lot less clutter on the screen and it looks easier to read.
foxtemple
Philadelphia, PA
2011 Ford Explorer
I just brought my ex in for the squeeky brake tsb and they said inks not covered under warranty because I am out of the one year 18000 mile brake warranty. Wouldn't the rotors and anchor bracket be in the bumper to bumper warranty? The dealer said they pads are the "causal" part.
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
Pads and rotors are "wear" items. Wear items are 1yr/12,000 miles. I have 32k on mine and they squeel every day. I always know when my wife pulls into the driveway. Had the tsb done at 6,000 miles and it started back up at 12k. Been living with it ever since.
foxtemple
Philadelphia, PA
2011 Ford Explorer
Just got the TSB done for 400 bucks and the noise is still there! Has anyone else had this problem? IF so what have you done? Very frustrating!
Dr Plastic
Newport News, Virginia
'15 Limited FWD
How the hell are they charging you $400 for a TSB plus the vehicle is (I am assuming) still under warranty? Of all the cars I have had I have never paid to have a TSB completed.
foxtemple
Philadelphia, PA
2011 Ford Explorer
The dealer told me the part that is causing the squeak is the pads [which are out of warranty]. They gave me the whole "TSB's don't extend your warranty story". I'm just wondering if anyone else got this TSB done and still has the squeak.
foxtemple
Philadelphia, PA
2011 Ford Explorer
I just noticed now that the weather is getting colder in my area tha tmy brakes constantly sound like they are rusty. Can anyone tha tlives in a cold weather place tell me if they are experiencing this with their ex too? I've been having an ongoing issue with my brakes making a grunitn gnoise when turning so I want to know if this rust type sound is normal or not.
FordService
Official Ford Rep
Dearborn, MI
Hey foxtemple,
Your dealership will be able to determine if your brakes are performing normally. I recommend making an appointment or mentioning this during your next scheduled maintenance or oil change appointment.
Crystal
flobes
Fort St John, BC
2011 XLT V6 4WD
Just had my 2011 ex, with 25000 km in for squeeky brakes. Thy said warranty is only good for 20000 km, I could either live with the problem or, pay for a brake job.
Thanks Ford..........You just sold me a Cadilac
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
As blwnsmoke posted in this thread, brakes are a 'wear' item and only covered for 1 year or 12,000 (20,000 km). This is not unusual and you will probably find other manufacturers likely have similar restrictions on 'wear' item warranties.
E Engine squeaky noise Stock 2011 - 2019 Ford Explorer Discussion 11
E 17 Sport squeaky noise Stock 2011 - 2019 Ford Explorer Discussion 3
D Squeaky sound when cold and on accelator Stock 2011 - 2019 Ford Explorer Discussion 3
A 2016 explorer XLT squeaky noise when turning the steering to the left only Stock 2011 - 2019 Ford Explorer Discussion 1
cwescapexlt4x4 Squeaky folding exterior mirror Stock 2011 - 2019 Ford Explorer Discussion 12
N Squeaky Power Moonroof Shade Stock 2011 - 2019 Ford Explorer Discussion 17
M Squeaky headliner Stock 2011 - 2019 Ford Explorer Discussion 26
P Squeaky Front suspension Stock 2011 - 2019 Ford Explorer Discussion 19
P Squeaky noise from dashboard when turning - 2011 explorer Stock 2011 - 2019 Ford Explorer Discussion 8
S 2013 Explorer standard vs heavy duty brakes Stock 2011 - 2019 Ford Explorer Discussion 4
B 2014 Ex. Sport - $1,600 for front brakes and LCA bushings? Stock 2011 - 2019 Ford Explorer Discussion 12
R "Brakes require immediate attention!" Stock 2011 - 2019 Ford Explorer Discussion 2
A Wheels that will clear the big brakes? Stock 2011 - 2019 Ford Explorer Discussion 1
B 2014 Explorer Sport Wired for Trailer Brakes? Stock 2011 - 2019 Ford Explorer Discussion 5
B No one can figure this out!! (Brakes) Stock 2011 - 2019 Ford Explorer Discussion 15
R Standard duty brakes upgrade to heavy duty Stock 2011 - 2019 Ford Explorer Discussion 50
O My rear brakes look like they are wearing funny. Stock 2011 - 2019 Ford Explorer Discussion 27
Jon M For those who upgraded from standard to heavy duty brakes om '11-'13s Stock 2011 - 2019 Ford Explorer Discussion 0
D Brakes engage while turning Stock 2011 - 2019 Ford Explorer Discussion 4
M Non-Sport excessive brake pedal travel and weak brakes?? Stock 2011 - 2019 Ford Explorer Discussion 31
F 2016 Ford Explorer Brakes and Rotors Life? Stock 2011 - 2019 Ford Explorer Discussion 2
T Rear Brakes - too much brake dust - dragging? Stock 2011 - 2019 Ford Explorer Discussion 0
E 2014 Explorer Base Rear Brakes Stock 2011 - 2019 Ford Explorer Discussion 2
D 2014 ltd brakes Stock 2011 - 2019 Ford Explorer Discussion 7
S 2012 brakes seem to stick Stock 2011 - 2019 Ford Explorer Discussion 4
T "Hard" brakes before start Stock 2011 - 2019 Ford Explorer Discussion 8
2 2017 Ford Explorer Brakes Stock 2011 - 2019 Ford Explorer Discussion 3
S Any Point in Bleeding Brakes on a Brand New Sport? Stock 2011 - 2019 Ford Explorer Discussion 8
C OEM Or Aftermarket Brakes? Recommendations. Stock 2011 - 2019 Ford Explorer Discussion 106
H Front brakes already 2016 sport!!! Stock 2011 - 2019 Ford Explorer Discussion 19
N Slotted and/or Drilled brakes discussion thread Stock 2011 - 2019 Ford Explorer Discussion 22
B Rear brakes Stock 2011 - 2019 Ford Explorer Discussion 17
S 2016 XLT Brakes Stock 2011 - 2019 Ford Explorer Discussion 10
U Standard vs Sport Brakes Stock 2011 - 2019 Ford Explorer Discussion 36
T Wrong Brakes Stock 2011 - 2019 Ford Explorer Discussion 10
V Front brakes Stock 2011 - 2019 Ford Explorer Discussion 6
1 Oh crap. I messed with my rear brakes and I think I screwed up. Stock 2011 - 2019 Ford Explorer Discussion 38
S Question on front brakes Stock 2011 - 2019 Ford Explorer Discussion 11
G Request for Rear Brakes TSB Details? Stock 2011 - 2019 Ford Explorer Discussion 13
D Pulsating Brakes - 2011 XLT Stock 2011 - 2019 Ford Explorer Discussion 11
M Ford Explorer: Are Your Rear Brakes Dragging... Most Likely Yes! Stock 2011 - 2019 Ford Explorer Discussion 326
S 2013 Explorer Brakes Stock 2011 - 2019 Ford Explorer Discussion 7
F Passenger side front brakes make "grunting sound" Stock 2011 - 2019 Ford Explorer Discussion 4
T '12 Ex needs brakes w/14K miles!? Stock 2011 - 2019 Ford Explorer Discussion 23
B TSB 11-10-29 Front Brakes Stock 2011 - 2019 Ford Explorer Discussion 5
B Brakes "Clunk" Stock 2011 - 2019 Ford Explorer Discussion 3
blwnsmoke Ford has released tsb for squeaking brakes!!!! Stock 2011 - 2019 Ford Explorer Discussion 95
D Squeaking / Squealing Brakes Stock 2011 - 2019 Ford Explorer Discussion 191
J 2011 seems to be holding me back with brakes or transmission Stock 2011 - 2019 Ford Explorer Discussion 25
M Issues with my A/C (again) Stock 2011 - 2019 Ford Explorer Discussion 8
Similar threads
