Squeaky left front. | Ford Explorer Forums - Serious Explorations
Squeaky left front.
ddjac123
tacoma, WA
'97 eddie bauer awd
how difficult is it to replace control arm ball joints & bushings for a 1997 Eddie Bauer AWD? The front left just started to squeek (loud) when I go over little speed bumps. Can I just lube up something?:salute::salute::thumbsup:
this thread will show you how. Just use search.
http://www.explorerforum.com/forums/showthread.php?t=194453
It may be the balljoint, a-arm bushings (upper or lower), or the tierod that is squeaking.
If you squirt the a-arm bushings with something such as WD-40, and it stops squeaking, you found the culprit.
The left side balljoint is one piece with the upper control arm. Some on the right are, some are not.
__________________________________________________________________________________
EDIT:
The lower balljoint replacement thread is also referenced in the thread I posted, as well as here ->
http://www.explorerforum.com/forums/showthread.php?t=188225
