TShockley
- October 4, 2011
- Pemberton, NJ
- 2007 Explorer Eddie Bauer
I have a 4.0L 6 Cylinder 2007 Explorer Eddie Bauer that is about 40k miles. When I drive I hear a high pitched squealing sound. I have had this problem in the past but it had resolved for the most part, now I am starting to notice it on a somewhat regular basis.
While driving I am hearing a squealing noise that only occurs while accelerating and in the ballpark of 1250-1500 RPM's, when I accelerate any further the noise goes away. I’m not sure what gear I am in when the problem occurs or if it even matters. Given the frequency of the noise it seems almost clear that it is definitely something belt-driven. The noise is audible in the ballpark of 1250 RPM and gets louder as I approach 1500 then disappears between 1500 & 2000 RPM. I also have not been able to reproduce the problem when the vehicle is in Park.
Checked the belt and it seems tight, appears to be in good condition. I brought this to Ford once before when I first bought the vehicle a year ago and they replaced the belt. Tried to explain the problem to the service tech but they assured me there was nothing they could do without leaving the vehicle with them for the entire day.
Any ideas on what could be causing the problem?
Also, The first time this happened I realized that it worsened when I turned the wheel but for some reason it only got worse when I turned the wheel to the left. I dont know if that is just a passive observation or if it effects the drive system differently. Doesnt seem to be the case now though.
