stalling and hard steering | Ford Explorer - Ford Ranger Forums - Serious Explorations
ranko
Suli,Iraq
2008 XLT
Hi,
My exp 1995 is killing me by continuous stalling, so i hope some one can help me, the problem is like this:
1- when i start the car (hot or cold), it will stall at some point when i am driving , then after five minutes or more it will stop stalling (but sometimes it still stalls).
2- the steering is much harder than it should be, it is not the same always some times it gets harder to steer while i am driving.
PS:
1- my IAC is replaced with an old second hand one, the old one was not working.
2- the number of stalling increased after i cleaned IAC and MAF sensor.
Thanks
Ranj
ranko
Suli,Iraq
2008 XLT
It running fine now
I have changed the AIC (or IAC) and cleaned the fuel lines and it running smoothly now.
Thanks
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Check power steering fluid. If fluid is okay, remove serpentine belt and rotate the power steering pump pulley. If it doesn't rotate freely, pump has seized.
ranko
Suli,Iraq
2008 XLT
problem occurs again
after a week from the fixing and AIC change i am back at square one, when i changed the AIC the rpm became 1000 when idle, so i decided to change it to 700-800 when i can, but i did not change it yet. any way now the rpm is about 800 without me changing anything, the stalling is back(but not the same as before), there is a gas smell coming from the car, and the car is lacking power when i push the accelerator.
regards
Ranj
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
The check engine light should be on -- have the computer scanned for any codes stored in memory.
Tbars4
Moderator Emeritus
Elite In Memoriam
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
...X2 on checking the codes..:thumbsup:
...This may be a dumb question but I see you are in Iraq..Is the vehicle from the states and all emission parts still installed, is it still stock???
ranko
Suli,Iraq
2008 XLT
The engine check light is not on, however i have a problem in Transmissions, it does not transfer to 3rd gear, i have to accelerate to about 35 km/h and release the gas to change to 4th gear.
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Maybe try checking the Oxygen sensor because the oxygen sensors control the air/fuel ratio:
http://mr2.com/TEXT/O2_Sensor.html
However, a faulty oxygen sensor should have thrown a code and the Check Engine Light should have came on (because oxygen sensors are within OBD-1 specifcation). So I dunno.... :(. If all else fails, you will probably have to take the vehicle into a Ford dealership because a technician will have to go through each sensor and see what is out of spec (maybe the faulty sensor is one that is not covered under the OBD-1 specification).
ranko
Suli,Iraq
2008 XLT
The vehicle is imported from Germany (of course it was used), all emission parts are there but not sure all of them works. any way i am planning to buy a Ford Escape 2008 soon.
Tbars4
Moderator Emeritus
Elite In Memoriam
...Honestly then, I would do a search and make sure all the vacuum lines are good...A cracked vacuum line would give you a higher idle and it may be as simple as the vacuum line going to the tranny...:dunno:
ranko
Suli,Iraq
2008 XLT
I haven't check those yet, but i noticed the battery (or electricity) gauge is moving up and down and the RPM moves down to 300-400 when its near to stall; usually i change the gear to N to avoid stalling (when stopping or slowing down).
NHale623
Eliot, Maine
95 XLT
It's a '95, there isn't a vacuum line going to the transmission.
