Standard vs Sport Brakes
unsung43120
LA, CA
2013 Ltd
I've read somewhere on here a few weeks back someone answering another poster's question on the basis of whether or not that person had sport brakes. I think the person had a limited or XLT.
This prompted me to ask, would getting a certain option (such as factory tow package), result in the factory upgrading a non-Sport's brakes to Sport's brakes on a non-Sport? Such as in the case of the factory adding an engine oil cooler whenever someone gets the tow package. I hope this question makes sense.
Also, can anyone provide step-by-step on upgrading standard brakes to Sport brakes?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
all the Explorers produced after the mid point in the 2013 model year have the same heavy duty brakes.
(invalid link removed)
Tony407
Portland, OR
2017 Ford Explorer Sport
Wait a second. Did I read that correctly? My '15 Sport has the same heavy-duty brakes as the Police Interceptor?
Tony
davido_
Sandy, Utah
2015 Ford Explorer Sport
Tony
You read most of it correctly.
All mid-year 2013 and newer Explorers have the same heavy duty brakes that previously were found only on the Sport and Interceptor Utility.
However, it sounds, from reading that, like the pad composition may be a little different on the Interceptor Utility's brakes.
ChristianWarrior
Manitoba
2014 Explorer XLT
Does 2014 Explorer have H/D brakes? Or is that only on police vehicles
peterk9
Staff member
Moderator
Callsign
VE3
expoman55
Location
Upstate NY
Upstate NY
2015 Explorer Sport
Does anyone know or can anyone confirm the Sport has bigger brakes (calipers) and rotors than tne other models? Does it the sport have the same brakes as the police interceptor?
just curious about performance brake kits and if work it over the sport stock brakes.
peterk9
Staff member
Moderator
Callsign
VE3
Your thread was merged with this one that should answer your question. It is also mentioned in other threads that the brakes are all the same post mid 2013 production.
ExPlat
Location
AZ
2016 Explorer Platinum
When the Dealer replaced the pads and turned the rotors on my 2016 ExPlat six months ago, they called me in the afternoon and said they didn't have the regular pads in stock so the car would be ready the next morning. However, if I wanted them to put some performance pads on at no extra cost the car would be ready that day, heck, I told them the performance pads would be great! My WO that should have been $179 for the front brakes was about $215 for adding the 'performance brake pads' then discounted back to $179.
I don't know what Explorer these 'performance pads' are built for but they have been excellent.
Eric F
So Cal
2017 Explorer XLT
A couple of questions...
How many miles did it take to need a new set of brake pads and a rotor turn? My initial thought is that your Ex is awfully new for needing that service.
Did you notice a significant difference in stopping distance/control? My month-old XLT seem to be pretty adept in the braking department. I'm having a hard time imagining something better.
Napalm
Memphis tn
I thought the only real different in Police utility or Interceptor brakes was the seals in the calipers - silicone vs nitrile rubber - (allows use of dot 4 or 5 brake fluid for the heat)
and the pad compound which you can just easily get by using any other pads.
Napalm
Memphis tn
Otherwise 14-today's are the same rotor diameter, metals, and brake pad areas.
ExPlat
Location
AZ
Yeah, doesn't sound right I admit. I bought this Ex with 6,000 miles on it and the previous owner must have used the brakes pretty hard because the front had a bad vibration, but I bought it anyway. The Tech at the Dealer said the pads were glazed and needed replacement, he was right, that fixed the problem.
I really can't compare a 'before and after' except to say the brakes work very well now. I'll try and remember to ask the Service Advisor about which exact pads were installed when I pick the car up tomorrow from other warranty work.
ExPlat
Location
AZ
Picked up my Explorer from the Dealer today and asked the new Service Advisor which brake pads they installed during my brake service last year.
This is the part number: GB5Z2001A
Front Pads
Part Number: GB5Z-2001-A
Positions: Front
Other Names: Brake Pads, Kit - Brake Lining
Replaces: BRF-41-, DG1Z-2001-D
Description: MKT. MKS. Heavy duty caliper.
Fits:
  • Ford:
    • Explorer,
    • Flex,
    • Police Interceptor Sedan,
    • Police Interceptor Utility,
    • Special Service Police Sedan,
    • Taurus
  • Lincoln:
    • MKS,
    • MKT
Tony407
Portland, OR
Who makes the heavy duty brakes? A Ford product or some other (Brembo, etc.).
Tony
Napalm
Memphis tn
Tony
as I understand it the rotors are thicker than previous (orginal 2013 brake rotor) and the pads are more aggressive compound but full ceramic not semi-metalic based) and the calipers are bigger (again Orginal 2013 brake caliper) - front and rear.
But I'm not 100% certain on all of that. from 14-forward we all have the same rotors, pad area, and caliper bodies (size) - with the police package cars having different seals in the brake calipers.
peterk9
Staff member
Moderator
Callsign
VE3
OP is asking about the manufacturer of the HD brakes.
Stick1969
Springfield, VA
2013 Explorer Limited
All I know is if you go to Summit Racing there are about 4 different rotor sizes to choose from for my 2016..... and you guessed it! I ordered the wrong size.....
Jon M
Mount Pleasant, SC
2015 Explorer XLT
I've been trying to figure out what I have for a while. According to the tech on my last visit to the dealer, I have original OEM brakes, but the pads have been changed.
I can't get the 'minor features' section of ETIS to expand, but it's worked in the past and shown standard duty brakes. Build date of 5/16/12.
However...I have ventilated rotors, not the solid ones, on all four wheels. I haven't pulled the wheels to measure, but the rotors look to be around 13" on all four.
When I put my VIN in on Fordparts.com, it shows standard duty rotors.
1125 (NBRR-12) Disc Brake Rotor Standard Duty Fr/Rr Calp And Pads (Front)
Vehicle Build Date after: 1/9/2012
If I search on Fordparts.com without a VIN, and I chose a 2015 instead of 2013, that same rotor comes up as one of the options, which it shouldn't, since there's not supposed to be standard duty brakes on those.
So, I have no idea what's on mine. I seem to recall reading the standard duty rear brakes were only 12" rotors. Mine are definitely around 13". I thought the heavy duty fronts were 14", but I could be wrong. Mine appear to be the same, or close, size front and rear.
peterk9
Staff member
Moderator
Callsign
VE3
Hi Jon. I discovered that the Ford ETIS site changed a month or so ago and I have the same issue. There was another link posted that supplied the same type of info but I can't seem to find it right now.
EDIT: found it; https://www.ford-trucks.com/forums/vindecoder.php
G 2017 Explorer Sport - extras or standard? Stock 2011 - 2019 Ford Explorer Discussion 28
S 2013 Explorer standard vs heavy duty brakes Stock 2011 - 2019 Ford Explorer Discussion 4
R Standard duty brakes upgrade to heavy duty Stock 2011 - 2019 Ford Explorer Discussion 50
Jon M For those who upgraded from standard to heavy duty brakes om '11-'13s Stock 2011 - 2019 Ford Explorer Discussion 0
F LED Fog Lamps standard on platinum? Stock 2011 - 2019 Ford Explorer Discussion 1
B Question on Standard 6-speaker Audio system Stock 2011 - 2019 Ford Explorer Discussion 3
R hitch receiver standard? Stock 2011 - 2019 Ford Explorer Discussion 15
J standard parts: xlt vs. limited? Stock 2011 - 2019 Ford Explorer Discussion 5
M 17s with bigger tires on 2016 Sport?? Stock 2011 - 2019 Ford Explorer Discussion 2
W 2017 Explorer Sport - Rumbling when when turning. Stock 2011 - 2019 Ford Explorer Discussion 6
M 2018 Ford Explorer Sport buzzing sound Stock 2011 - 2019 Ford Explorer Discussion 2
A Sport Appearance wheels on Sport Explorer Stock 2011 - 2019 Ford Explorer Discussion 2
T 2015 Explorer Sport vs. 2016+ Sport...Disappointing Test Drive. Stock 2011 - 2019 Ford Explorer Discussion 5
K New wheels and Tires in 2016-19 explorer sport Stock 2011 - 2019 Ford Explorer Discussion 1
D 2016 Sport drops power or boost under load Stock 2011 - 2019 Ford Explorer Discussion 2
T 2013 Ford Explorer Sport Whistling during acceleration Stock 2011 - 2019 Ford Explorer Discussion 0
M 2014 Sport, no boost Stock 2011 - 2019 Ford Explorer Discussion 12
B 2015 Sport Rear 40/60 Seat Removal Stock 2011 - 2019 Ford Explorer Discussion 2
W New wheels/tires on '17 Sport Stock 2011 - 2019 Ford Explorer Discussion 6
J What happened to my 2017 Explorer Sport??? (Turbo and Engine issues) Stock 2011 - 2019 Ford Explorer Discussion 11
T 2013 Explorer Sport Whistling Stock 2011 - 2019 Ford Explorer Discussion 0
M 2016 Explorer Sport Coolant Flush Stock 2011 - 2019 Ford Explorer Discussion 8
W Rear Coil Spring Differences between Sport and Police Stock 2011 - 2019 Ford Explorer Discussion 11
R Steering assist fault on a new sport Stock 2011 - 2019 Ford Explorer Discussion 6
M 2013 Sport random little issues Stock 2011 - 2019 Ford Explorer Discussion 7
R 2017 Explorer Sport 2nd row console Stock 2011 - 2019 Ford Explorer Discussion 7
F New member...ting/pop/click noise-front half shaft 2015 Explorer Sport Stock 2011 - 2019 Ford Explorer Discussion 10
C 2017 Sport White/Blue Smoke on Startup/Acceleration Stock 2011 - 2019 Ford Explorer Discussion 10
J 2016 Sport Wiring Issue? Stock 2011 - 2019 Ford Explorer Discussion 2
S What fuse type in a 2019 Sport Stock 2011 - 2019 Ford Explorer Discussion 4
F 2017 Explorer Sport takeoff surging Stock 2011 - 2019 Ford Explorer Discussion 8
C In the market for a 19- Sport or Limited? Stock 2011 - 2019 Ford Explorer Discussion 2
N Help with Tire Size for Explorer Sport 2014 Stock 2011 - 2019 Ford Explorer Discussion 8
D 2016 Ford Explorer Sport seat uncomfortable Stock 2011 - 2019 Ford Explorer Discussion 1
B 2016 Explorer Sport Driver seat heater working for back but not seat? Stock 2011 - 2019 Ford Explorer Discussion 3
B 2014 Ex. Sport - $1,600 for front brakes and LCA bushings? Stock 2011 - 2019 Ford Explorer Discussion 12
B Explorer Sport ac question Stock 2011 - 2019 Ford Explorer Discussion 2
M Sport wheels and tires with Ford tire sensors Stock 2011 - 2019 Ford Explorer Discussion 7
Gilbert M Vega High Temperature "sport" Decal Stock 2011 - 2019 Ford Explorer Discussion 1
C 2016 Ford Explorer Sport, Passenger floorboard completely flooded Stock 2011 - 2019 Ford Explorer Discussion 11
B 2014 Ford Exployer Sport Leak in passenger floor board Stock 2011 - 2019 Ford Explorer Discussion 4
Kurama 2014 Sport - Wax Question Stock 2011 - 2019 Ford Explorer Discussion 7
B 2016 XLT ecoboost (non sport) Shuts off while driving Stock 2011 - 2019 Ford Explorer Discussion 4
T 2014 Sport Seat comfort Fix Stock 2011 - 2019 Ford Explorer Discussion 5
K 16' Explorer Sport Parking Brake Adjustment? Stock 2011 - 2019 Ford Explorer Discussion 11
N 2016 Explorer Sport lugging issue. Stock 2011 - 2019 Ford Explorer Discussion 4
M 2016 sport throwing p0327 code Stock 2011 - 2019 Ford Explorer Discussion 1
M 2013 Sport with P0299 code (Underboost) Stock 2011 - 2019 Ford Explorer Discussion 2
B Very intermittent mirror issue 16 Sport Stock 2011 - 2019 Ford Explorer Discussion 6
D About to join the Ford Explorer Sport family.. Stock 2011 - 2019 Ford Explorer Discussion 7
Similar threads
