pcsullivan91
- December 29, 2007
- Huntersville, NC
- '01 Explorer Sport Trac
When I leave my truck over night and crank it in the morning (especially when it's cold), the RPM's are half normal and the truck shakes as if it's going to stall. The lights will flicker and the exhaust smells lean.
After 5-10 second the idle will stabilize or I can manually fix the idle by giving it a little gas. After the idle returns to normal the truck runs and idles fine until the end gets cold again.
Also, might be part of the issue. If I get in my truck, put the key in and turn it without letting the fuel pump fully run the truck will turn over for 10 seconds or so before catching? Slow fuel pump?
recently have changed: fuel filter, spark plugs, PCV, IAC
