donhart
- July 11, 2009
- Palmer, Alaska
- 1992 Explorer
Starter relay wiring photo needed urgently for a 1992 Ford Explorer. Would not start. Found one terminal had broken on the molded plug that fits across both posts of the relay. Removed the wiring, split the molded plug, cleaned the one wire of insulation at the end. Replaced wiring. Apparently wired wrong. Engine started and starter continued to engage. Cut positive battery cable. Removed the wires from the relay. Need photo of wiring for the relay urgently, to get it right before I try again. Thanks, DonHart
