Ryan1
- December 18, 2000
- White Bear Lake, MN
- 94 XLT
ok,
if you look at the starter relay, on the passanger side fenderwell, there is a Positive stud and a negative stud.
Also there is a smaller stud at the top which is the power for the relay small wire with a red boot on it. I believe this comes from the ignition.
Anyhow, im not getting power to the starter relay through this little wire. I tested it and it read dead, with the ignition in the start position. Then it started reading 13.34 volts when I turned the ignition. When I let off the ignition, it was still reading 2.3 and 3.5 and soforth, without turing the ignition. And my truck was starting fine for a day
so Again today my truck stops starting. So I have to manually jump the positive and negative on the starter relay
Where does this wire actually come from and what could be causing it to do this? The starter relay is not bad.
I need some imput, I hate having to pop my hood and whoop out a screwdriver anytime I wanna go somewhere.
Thanks
Ryan
Thanks
Ryan
