DemoXide☣️
- May 29, 2020
- Mission Viejo CA
- 2000 Explorer V6 4.0L. SO
1st post so ty in advance for any help
Flashing check engine light as I pass local AutoZone. so I pull in to use their OBD2 scan tool which gives error codes in cylinder 1 and cylinder 5 misfires upon returning to my vehicle attempt to start and starter spins but won't engage the flywheel have it towed home buy a new starter install it and still the same problem. Flywheel teeth looked fine. Also when turn ignition key I first quickly hear a single hammer strike sound( presume starter thrusting out to engage) and then just the whine of starter spinning. A penny for. your thoughts or your 2cents worth is appreciated
