2000XPLORERSPORT
- January 16, 2007
- Location
- michigan
- lambertville,mi.
- 2000 FORD EXPLORER SPORT
Ok, sorry kinda long, but i need some help!!!! so i own a 2000 explorer sport, 4.0l. i had belt squeal for a while the past year or so. i found my tensioner was staying stuck in the outward position. putting too much tension on the belt and squealed at startup. so i got a new tensioner. seemed to work. but now for months when i go to start it, it cranks then clicks like the battery is dead. now it is a 15 year old optima red top. but it probably only has 10 years of use because i don't drive it a whole lot. but the battery charges up fine & holds a charge. example- the battery is charged to 14.5 volts, i go to start it and when it starts to turn over about a second or two it clicks like the battery is low. i hooked up my volt meter and watched, when it goes to crank over the voltage drops to 7-8 volts!!!!! then soon as you stop trying to crank it over, the voltage climbs back up within seconds. i hook up jumper cables to my parent's car with it running my truck will start. but i could have my battery charged to 14+ volts and it drops to 7-8 then back up. i was thinking the starter might be going bad? i mean it is the original starter with about 158,000 miles on it. any ideas/suggestions? i really need to figure out what's going on!!! thank you!!!!
