Starting issues. | Ford Explorer - Ford Ranger Forums - Serious Explorations
Starting issues.
RevLuvv
Albuquerque
99 Explorer EB
I have a 99 explorer with a weird starting problem. With a full battery( measured voltage and placed it on a starting charger) -- I place key in ignition. turn to on position. gauges fire up but voltage is low. I turn the key and total discharge ( no lights or indicators in cabin) It will not reset. I remove battery terminal, wait replace it and the interior lights come back on. I repeat with the same results. The night it first happened it started but while depressing the gas the voltage showed a huge drop. At idle, the computer stated voltage OK. I found it odd and turned it off for a restart. When I did I experienced the problem listed above. Any ideas?? Relays??
Thanks in advance!
Patrick:
Lacky01
Eugene, Oregon
1998 Sport
Does the same thing happen when you try to jump start? I've had the battery be so dead that it registered as charged for a bit. Maybe something to look at. Also check the cables running to your battery, any corrosion will cause low voltage even with e fresh battery.
If those are good, look in the power distribution box under the hood. Your manual will tell you which relay is for the starting system. Switch that relay with a similar one nearby and see if that makes a difference.
RevLuvv
Albuquerque
99 Explorer EB
Thank you
Instead of removing the cable each time I just wiggled the negative. It looks very poor and corroded. I have about 180k on it but it still looks new and I want to relpace anything that I can to keep it reliable. The threads are saying a 1/0 cable for the negative. Does that sound right? Is there something better?
Is it difficult to remove the connection from the solenoid? I have been looking for diagrams. I sure would like to do it from the top if possible.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
