Starting Problem | Ford Explorer - Ford Ranger Forums - Serious Explorations
Starting Problem
walterd140
Ludlow, Massachusetts
'94 Sport
Hi All. Developed an issue starting. 94 stock Explorer with 160,000 miles. The engine would crank & crank & crank. Finally starting after a lot of cranks or me physically stepping on the gas.
I changed out the air & fuel filter, plugs & wires. Still does it.
Here's a new kick.. I crank a few seconds, stop, then turn the key & it fires right up.
I do have a slight coolant leak & a fuel leak as well (hope to fix fuel leak real soon).
Any help?
Thanks in advance
Walter
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
Verno
Waynesboro, TN
94 XLT
Sounds like your issue is either fuel pump or fuel pressure regulator. Do a fuel pressure test first.
walterd140
'94 Sport
Thanks Verno, but the fuel pump is either working or not, right?
Verno
Waynesboro, TN
94 XLT
Not necessarily. When they begin to fail/get weak they will basically work intermittantly.
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Or the pump itself works fine, but the check valve in the pump (that's supposed to keep the rail pressurized when the key is off) goes bad. The fuel rail depressurizes, which means it takes longer for the otherwise good pump to pressurize the system.
walterd140
'94 Sport
Just out of curiosity, what perssure should I get on the rail? Also, do I check it with the engine running, not running, or key turned to start (to get the fuel pump humming)?
MrShorty
Spanish Fork, UT
yes (by that I mean you should measure pressure under all those conditions). You might go to the Under the Hood forum and review the fuel pressure test mini-diary thread. spec fuel pressure is 40 psi KOEO.
