starting/stalling issues
armysoldier30263
Shaw AFB, SC
05 BLACK 4.0 XLT
hey yall got another question,
im currently deployed and the explorer is having some issues. my wife says it is very difficult to start in the morning and stalls ALOT. it also stalls when its hot not as much but still alot. my buddy is looking at the manual and it says to check the fuel injectors. neither one of us know how to check the injectors. anyone else had these issues? i would love input before i have to start throwing parts at it. im not sure if its a fuel or air issue
JoshMcMadMac
Waynesboro, PA
2002 Mercury Mountaineer
It must be throwing a check engine light, so get the code(s) pulled from a local auto parts store for free and post them up here.
armysoldier30263
Shaw AFB, SC
05 BLACK 4.0 XLT
i have a scanner and it has no codes
JoshMcMadMac
Waynesboro, PA
That makes no sense. It should be giving a lean or rich condition, or skewed MAF values, or misfires, or something. I would start with simple stuff, like looking around the engine bay for something lose our out of place. Check fuel pressure, check for any obstruction of the air intake, make sure the battery is up to snuff, and look around for any loose wiring.
T 2004 V8 Explorer Starting problems after alternator Modified 2002 - 2005 Explorers 1
J 2004 Explorer starting issue Modified 2002 - 2005 Explorers 1
R Not starting Modified 2002 - 2005 Explorers 1
W Starting 02 Ex V8 turbo build. Need help & info Modified 2002 - 2005 Explorers 10
0 starting the exhaust this week.. Modified 2002 - 2005 Explorers 11
n.gardner Trouble Starting Modified 2002 - 2005 Explorers 5
NHarris Project Starting: Magnaflow Exhaust Modified 2002 - 2005 Explorers 123
D Just starting off Modified 2002 - 2005 Explorers 12
K Random Stalling...? Modified 2002 - 2005 Explorers 8
T BTF Spacer Install Issues Modified 2002 - 2005 Explorers 0
N Factory alarm issues Modified 2002 - 2005 Explorers 2
M Help! Newbie with A/C issues. Modified 2002 - 2005 Explorers 1
L power locks issues Modified 2002 - 2005 Explorers 1
C Buying A 05 Explorer, 4x4, Trany Issues Modified 2002 - 2005 Explorers 2
P 4.10 issues??? Modified 2002 - 2005 Explorers 5
I 2002 4.6 shift issues Modified 2002 - 2005 Explorers 0
D Traxda lift - More issues! Anyone else? (2002 XLT V6) Modified 2002 - 2005 Explorers 13
M Lift dilemma/issues Modified 2002 - 2005 Explorers 11
T Camber issues On rear Modified 2002 - 2005 Explorers 1
M Rear Alignment Issues (Lifted 2.25/1.75) Modified 2002 - 2005 Explorers 7
M Issues with new radio Modified 2002 - 2005 Explorers 2
D steering wheel issues Modified 2002 - 2005 Explorers 9
G btf spacer lift ball joint issues Modified 2002 - 2005 Explorers 4
M Alignment Issues HELP!!!! Modified 2002 - 2005 Explorers 8
B Power Seat Issues Modified 2002 - 2005 Explorers 17
B Cragar wheels with 265/75/16..what size rims? Rubbing issues? Modified 2002 - 2005 Explorers 7
B BTF spacer/ KYB install issues. Modified 2002 - 2005 Explorers 13
B low catalyst and running issues Modified 2002 - 2005 Explorers 9
M I have the well known Crapped out wheel bearing issues again!!! Modified 2002 - 2005 Explorers 15
R electrical issues due too many h.i.d./fog/driving kits? Modified 2002 - 2005 Explorers 5
shadowless127 Issues with In Channel Vent Visors Modified 2002 - 2005 Explorers 13
B Any issues with aftermarket headunits? Modified 2002 - 2005 Explorers 14
D Weird electical issues Modified 2002 - 2005 Explorers 7
P 2004 XLT 4.0 Cold Air Intake Issues... Modified 2002 - 2005 Explorers 10
Similar threads
