NTxPSA
- May 17, 2020
- Location
- Pilot Point, TX
- Pilot Point
- 2020 Ford Explorer ST
Looks like Steeda is releasing their sway bar...WOOOOHOOO!!!
Looks like stock is 7/8 inch and this one is 1 1/8"....
DESCRIPTION
Steeda's Explorer adjustable rear sway bar gives you control of your Explorer's handling. The sway bar reduces body roll for more neutral handling, allowing you to carve corners with your SUV. The sway bar offers a comfortable ride for your SUV but keeps things level through corners.
Stability and control. Distributing the weight of your Explorer between the rear wheels when turning, the sway bar helps to keep your SUV level in corners and planted to the road. Trailer sway is reduced when towing and control is better with heavy payloads, so you can drive with confidence.
Strong construction. Steeda's sway bar is designed, engineered, and manufactured in the USA and is made from a 1-1/8 inch solid steel bar for long-lasting performance and durability. By comparison, the Explorer ST sway bar is 7/8 inch diameter. CNC-machined billet steel ends offer greater strength than the coined ends on other bars. The bar is powder-coated Steeda blue for protection from the elements and to let people know your Explorer is equipped with Steeda parts.
Sporty feel. The flat and level handling that the sway bar provides makes driving more exciting and enjoyable. Corner carve with your Explorer and get tight handling like a sports car with the upgraded sway bar. 3-way adjustability lets you fine-tune the sway bar stiffness to meet your needs and provide the control you want.
Features & Benefits:
Steeda 555-1030 Explorer Adjustable Rear Sway Bar (20-21)
www.steeda.com
DESCRIPTION
- Made in the USA
- Neutral and flat handling
- Reduced body roll
- More control with heavy loads
- Less trailer sway when towing
- Maintains a comfortable ride
- 1.125" solid steel sway bar
- 3-way adjustable
- 4x the stiffness of the OE bar
