Steel Brake line ABS to front wheel | Ford Explorer - Ford Ranger Forums - Serious Explorations
all4ford
95 Explorer
I have a leaking front brake line from the ABS pump to the front brake line on my 95 Explorer. Does anyone know what style flare (i.e. bubble, double flare) and line size I need to replace it?
J_C
Florence, KY
1998 XLT 4WD 4.0L SOHC
Double flare, 3/16" line, 3/8" nuts, except reuse the larger OEM nut on the ABS end (bottom ABS nut stays on, no need to remove it but you'll want a 2nd wrench to hold it still while the top ABS nut is loosened).
1996 XLT V8 Explorer4406
I'm replacing the lines on my ranger with this poly coated line from autozone, it seems to have a really corrosion resistant coating and is easy to bend with your fingers. you'll still need a flaring tool though
