Steering Box questions | Ford Explorer - Ford Ranger Forums - Serious Explorations
LO, MI
94 eddie baurer 8 in lift
i have a 94 explorer with a 8 in lift, and it needs a new steering box....i was wondering if i could swap one in from a 2wd 93 ranger....let me kno guys:D
Flip4ford
Newton, KS
94' Sport
I heard (that is heard, not a known fact) that the steering box is the same for the rangers- and f-150s-- I want to retype - I heard it from a guy, who knows a guy, who dated a steering box once-- You can do a search for steering gear and find the answer as a cold hard fact.
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
I can say Ranger, Explorer, e-150 and f-150 and f-250 boxes are the same. I can't tell you exactly what year of each but that steering box has been used by ford for years.
I've had an f-250 and an e-150 van steering box on the X over the years.
~Mark
nitro71
Spokane WA
You might check the part at rock auto. I recall seeing a wide range of vehicles all using the same steering box. G'luck!
G
geoph1986
According to ADP Hollander Interchange, the following vehicles use the same steering box. Keep in mind that only the steering box is the same and the pitman arm could be different.
BRONCO 80-96 Power Steering
BRONCO II 84-90 Power Steering
EXPLORER 91-94 Power Steering
FORD F100 PICKUP 80-83 Power Steering
FORD F150 PICKUP 80-96 Power Steering
FORD F250 PICKUP 80-96 Power Steering
FORD F250 PICKUP 97 Power Steering; over 8500 GVW, 2 bolt cover & flare hose fittings
FORD F350 PICKUP 80-96 Power Steering
FORD F350 PICKUP 97 Power Steering; 2 bolt cover & flare hose fittings
FORD F450 PICKUP 88-96 Power Steering
FORD F450 PICKUP 97 Power Steering; 2 bolt cover & flare hose fittings
FORD VAN 82 Power Steering; from 3/82
FORD VAN 83-91 Power Steering
FORD VAN 92 Power Steering; (E150 thru E350), exc. tag SPA-ER and FG
FORD VAN 93 Power Steering; E150 and E250
FORD VAN 94 Power Steering; thru 4/94, E150 and E250
MAZDA B-2300 94-97 Power Steering
MAZDA B-3000 94-97 Power Steering
MAZDA B-4000 94-97 Power Steering
MAZDA NAVAJO 91-94 Power Steering
RANGER 83-97 Power Steering
