alaskan155
- June 27, 2006
- washington
- 4dr 94,97,01 eb,xlt,xls
well my 94 has 241k on it, and the steering box is getting old and sloppy and im to cheap for red head right now so my question has anyone swapped in a 97-03 f150 box, i see them a dime a dozen on car-parts for $40 a piece they have the 4 bolt box like the e99 superdutys and are 32 spline so i believe the stock pitman arm will work.... only difference i see is the input splines..
94 steering box specs
More Information for CARDONE 277516
Package Contents Gear, Instruction Sheet, Flushing Instruction, Instruction Tag
Color/Finish Black
Product Condition Remanufactured
Input Shaft Spline Count 29 + Flat & Groove
Number of Mounting Holes 3
Hose Port Type Seat
Total Turns Lock To Lock 4.0
Pressure Port Thread Size 1/2 x 20
Return Port Thread Size 5/8 X 18
Pump Rotation Reverse
Pitman Arm Included No
Input Shaft Type Splined, Single Flat
Steering Box Type Power Steering
Return Port ID Size 0
Pressure Port ID Size 0
Input Shaft Diameter (in) 0.73
Input Shaft Diameter (mm) 18.42
Output Shaft Diameter (mm) 33.32
Output Shaft Diameter (in) 1.31
1999 f150
More Information for CARDONE 276565
Package Contents Gear, Instruction Sheet (2), Flushing Instruction, Instruction Tag, Sealing Kit
Color/Finish Black
Input Shaft Spline Count 26 + 2 Flat & Groove
Hose Port Type O-Ring
Total Turns Lock To Lock 3.3
Pump Rotation Standard
Input Shaft Type Double Flat
thoughts?
Color/Finish Black
Hose Port Type Seat
1999 f150
Color/Finish Black
thoughts?
