steering play. | Ford Explorer Forums - Serious Explorations
steering play.
stoneyj69
palmer, ak
1994 explorer xl
i have play back and forth in my steering wheel. anybody have any ideas.?
yea i know what you mean i have a 94 4x4 xlt and it has play back and forth it gets on your nerves after awhile lol...wish i knew how to fix it too
One of three things:
1 Worn out Tie Rods
2 Worn out steering gear box
3 Worn out linkage in steering shaft
It's probably #1 or #2. So check your tie rods. If they are loose: problem found. If they are tight then move on to the steering gear box. There is an adjustment screw on the gear box. Tighten that up a bit and see if that helps. If so, tightening the adjustment screw is just a short term fix, you need to replace the gear box. If both of those check out it's probably the u-joint in your steering shaft.
