jcasey007
- March 17, 2009
- Stratford Upon Avon, Warwickshire
- Jeep Commander 5.7L HEMI
It's just taken me a day and half to change the rack, what a nasty job!
It didn't start well as all three boilts holding the front tow hook to the chassis rounded off and had to be cut off.
It actually took 9 hours to get the old rack out, problems ranging from seized nuts and a complete failure to undo the presure pipes as you can't get a spanner on it. In the end I had to remove all the pressure pipes just to be able to got to the pipe to the pump.
In the end I 'modified' 2 x 18mm spanners, one I cut a slot in the ring end and the other I put a dog leg into it with my 10 ton press (and cut it in half to shorten it)
It's not often i'm reduced to tears but when the new rack got stuck, I might have had a manly weep under the car (or was it crap in my eye)
Anyway, It's mostly in apart from the anti-roll bar, I ran it up to chack for leaks and it's all good.
I just wish I could meet the person who designed the steering rack area in a dark alley one day.
Jim
Jim
