sunfish32
- January 18, 2006
- East Moriches, NY
- '97 5.0L XLT
I have a 1997 5.0l with 105k. it recently sat for about a month and upon starting it and trying to move it on a cold day i let it warm up 10 min and when i finally started to drive it immediately noticed the power steering was not working before the truck sat there were no leaks in the power steering but now it seemed to be leaking from the steering rack. the fluid resevoir was almost empty at this point. i put the truck on stands with the wheels off and found that the rack was suddenly leaking from both ends where the system had been functioning perfectly before the truck sat. in diagnosis i filled up with fluid and turned the wheel with the tires off and there was a bumpy feeling or roughness felt in the steering wheel. i have since ordered and began installing a new rack which is an involved project and new power steering pump. the best theory i can come up with is that for some reason some pressure regulator or check valve may have gotten stuck from the cold and as a result allowed the pressure to get to high and blow out the seals on the rack. but i am not satisfied with this has anyone else experienced anything like this?
thanks
mike
thanks
mike
