Steering shaft play?
Explorer Junky
Grand Rapids, Mi
1997 XLT 4 dr 5.0
I have a1997 Ex with 5.0 and AWD. I was just wondering how much play if any should there be in my steering shaft? I reached through the wheel well to check plug wires and decided to give it a check. It has a little play in it. Should I be worried about this?
S 1996 Explorer V8, 2WD intermediate steering shaft. Stock 1995 - 2001 Explorers 1
poker4me007 Looking for a lower steering shaft. Stock 1995 - 2001 Explorers 11
M Steering shaft adjustment Stock 1995 - 2001 Explorers 4
N Who makes an after market Steering Shaft? Stock 1995 - 2001 Explorers 7
D 1996 explorer xlt lower steering shaft u joint Stock 1995 - 2001 Explorers 5
E lower steering shaft Stock 1995 - 2001 Explorers 6
M Tips on aquiring/refurbishing lower steering shaft Stock 1995 - 2001 Explorers 14
J 1996 Lower Steering Shaft Stock 1995 - 2001 Explorers 0
K Steering shaft issues.... Stock 1995 - 2001 Explorers 11
J Steering Gear Lower Shaft-1995 Frord Explorer Stock 1995 - 2001 Explorers 0
B Wanted Lower steering shaft Stock 1995 - 2001 Explorers 24
1 Steering Intermediate Shaft Question? Stock 1995 - 2001 Explorers 9
K Intermediate steering shaft replacement u-joint Stock 1995 - 2001 Explorers 2
1 steering shaft hitting spark plug wires!!! Stock 1995 - 2001 Explorers 6
1 96' Ex Intermediate Steering shaft. Stock 1995 - 2001 Explorers 4
J Lower steering shaft no longer available from For Stock 1995 - 2001 Explorers 2
H Steering shaft replacement Stock 1995 - 2001 Explorers 4
N steering shaft Stock 1995 - 2001 Explorers 1
D Upper Steering Shaft Stock 1995 - 2001 Explorers 7
S Sorry, another steering shaft question Stock 1995 - 2001 Explorers 2
fast_dave Can you JUST replace the U-Joint on Lower Steering Shaft??? Stock 1995 - 2001 Explorers 1
R Steering Shaft Boot Stock 1995 - 2001 Explorers 1
G how to swap upper steering shaft??? Stock 1995 - 2001 Explorers 0
J 96 lower steering shaft joint Stock 1995 - 2001 Explorers 4
D Question for those needing a lower steering shaft for an Explorer. Stock 1995 - 2001 Explorers 12
N Intermediate steering shaft? Stock 1995 - 2001 Explorers 5
gavin Lower Steering Shaft Stock 1995 - 2001 Explorers 12
L Steering Shaft? Stock 1995 - 2001 Explorers 2
I Steering Shaft Stock 1995 - 2001 Explorers 2
T Steering - Lower Shaft & Joint Ass'y Stock 1995 - 2001 Explorers 13
V Lower Steering Shaft Replacement Stock 1995 - 2001 Explorers 2
C 2001 steering and ignition won't unlock after shift tube replacement Stock 1995 - 2001 Explorers 1
S [2nd gen 2000] Huge play on steering wheel Stock 1995 - 2001 Explorers 10
A What causes knocking noise when steering wheel turned right/left, idling at standstill? Stock 1995 - 2001 Explorers 4
T Steering wheel swap Stock 1995 - 2001 Explorers 0
C Steering damper Stock 1995 - 2001 Explorers 3
allmyEXes 1997 steering sector? removal Stock 1995 - 2001 Explorers 19
S ‘99 Explorer, power steering hose and Coronavirus Stock 1995 - 2001 Explorers 5
B Steering wheel swap? Stock 1995 - 2001 Explorers 4
H Steering wheel lights. Stock 1995 - 2001 Explorers 1
Brem95 How to remove steering wheel cover? Stock 1995 - 2001 Explorers 3
T Jerky Steering Stock 1995 - 2001 Explorers 7
S 2000 XLT steering column sensors Stock 1995 - 2001 Explorers 25
Z Single tick noise heard and felt in steering wheel when turning Stock 1995 - 2001 Explorers 10
S Violent shaking in the car and steering wheel Stock 1995 - 2001 Explorers 8
C I made HEATED Steering WHEEL - DIY Stock 1995 - 2001 Explorers 4
6 steering and driveline problems Stock 1995 - 2001 Explorers 4
K Steering Column RAG joint Stock 1995 - 2001 Explorers 6
C 2000 Exploder sport 2wd power steering Stock 1995 - 2001 Explorers 5
P Steering wheel not square with dash Stock 1995 - 2001 Explorers 3
Similar threads
