jgfarley47
- November 23, 2021
- Gulf Breeze
- 1999 Ford Explorer XLT 4D
What controls are on the 1999 Ford Explorer XLT
All of them..What controls are on the 1999 Ford Explorer XLT
The OP should have been more clear, but the heading asks about steering wheel controls. To the best of my recollection, on the XLT it's just cruise control (and horn, of course).All of them..
But seriously folks, what exactly do you mean?
My apology. I meant to ask what controls are on the right and left hand side of the steering wheel of a 1999 Ford Explorer XLT.All of them..
It was funny how my original degraded, not linearly. It looked good until two years ago, then the black coating started peeling off, then last summer when it got hot outdoors, they turned very shiny/gooey, unlike any summer prior.
I'd never cleaned it with anything more than mild detergent solution, and can't even recall using the cruise control buttons in the last decade or so. They appear to be silicone rubber so probably not a good idea to put armor-all/etc silicone on them.
I did have a bulb burn out and replaced it with an LED (hard soldered on not a "bulb" retrofit) around 5 years ago. The new aftermarket ones like I linked (probably Donalds' too) are LED rather than incandescent, didn't notice much difference in light output but a little less uniform than the original.
I've only had mine installed since summer, looks good still but no idea how long they'll hold up.
I've replaced several in all the Explorers I've owned. The originals (old by the time I got them) were a hard plastic and the face of them were eaten away. The replacements were a soft vinyl. They looked the same, but didn't feel the same. You can tell there is a little button under the face that you need to make sure you push to work the control.It was funny how my original degraded, not linearly. It looked good until two years ago, then the black coating started peeling off, then last summer when it got hot outdoors, they turned very shiny/gooey, unlike any summer prior.
I've replaced several sets with all the Explorers I've owned. The originals (old by the time I got them) were a hard plastic. The replacements were a soft vinyl. You can tell there is a small button you need to push under the control for it to work. The replacements seem to hold up OK.It was funny how my original degraded, not linearly. It looked good until two years ago, then the black coating started peeling off, then last summer when it got hot outdoors, they turned very shiny/gooey, unlike any summer prior.
