KDK241
- August 17, 2018
- Maplewood, Minnesota
- 2000 Mercury Mountaineer
Hello, I have been lurking on here for a few years now and have fixed many things on my trucks thanks to this forum but this time I need help.
I have a 2000 Mercury Mountaineer 5.0 AWD with 109,000 miles that was very well taken care of by the previous owners. I have owned it since 101,000 miles and this started a few days after I bought it.
The problem I'm having started with pulsating brakes at slower speeds and steering wheel shake when braking at highway speeds that seems to be coming from the front driver's side. I immediately changed the front brakes and rotors but the problem continued. I have replaced the front wheel hubs and when I got an oil change they found my inner tie rod was loose on the driver side so I just changed the inner and outers on both sides today along with the sway bar links.
The pulsating at slower speeds has lessened, it is a very light pulsation only if I'm going 40 mph or higher, and then only if I hit the brakes semi-hard, but it still shakes badly when braking at highway speeds. The calipers seem to be working properly and I got new tires put on yesterday.
The ball joints seem fine, no play in the wheel when jacked up but I have 2 upper control arms from my Explorer that are only 2 months old so I plan on changing those this weekend before I get an alignment done.
Sorry for the long first post but I'm not sure what else there is to check and TIA! - Katie
