trailblazer295
- February 10, 2009
- Ontario
- 02 Explorer Sport
I've had this ongoing issue for the past while, before I bought the truck the front drivers bearing was shot and was replaced by the dealer. It started as a subtle vibration and the steering wheel would wobbly on the highway then got much worse after only a few hundred km. Took it to a tire shop they found cupping on the wheels. The rotated front to back and it was dramatically improved, it was still present but seemed to change. Sometimes it would be gone others it would come back a bit more. There was also a grinding sensation I could feel through my feet. Inspecting the front the guide pins for the calipers were tight both on the drivers side and one on the passenger side. I cleaned them and greased them and put it back. I didn't take it back on the highway. Two weeks later I had new tires put on a set of rims I had bought used. Took it on the highway for the first time and the wobble is worse then previously. The strangest part is when I was on the inside lane and the road was slanted the wobble almost completely disappeared then when the ground leveled out it returned. Also the truck will go straight, letting go of the wheel it wobbles about an inch but doesn't pull left or right. And when making subtle movements with the wheel the truck responds do dead space I could detect like my dads old Cherokee. I jacked the front when I got home from work but no bearing play that I could feel. I ran my hands over the tires and didn't feel any imperfections.
I can see something being loose or worn but the change in angle making it go away is really puzzling. Any ideas?
