stereo wiring | Ford Explorer - Ford Ranger Forums - Serious Explorations
stereo wiring
filb
Location
gold coast .Australia
gold coast
04 explorer uz
Hi all can anyone point me in the right direction as to what colour wire im looking for i am wanting to put an aftermarket stereo in my ex and somebody has done this before me and the factory harness was cut out ive located all the speaker wires and most of the power wires but am looking for the factory amp wire i have no idea what color wire or wires im needeing to find can anyone help with the colors please
Thanx
Mbrooks420
High Voltage.
1998 Mountaineer AWD
Th factory amp for what? The subwoofer?
Spudhut
US Navy Submariner
Location
NW Arkansas
Bentonville, AR
1997 Explorer Sport - 4x4
Callsign
KG5SPB
You looking for the 'trigger lead' or looking to install an amp? Unclear what your asking o_O
Mbrooks420
High Voltage.
I think you are looking for a red wire with a black tracer. Do you have a test light or multimeter? I would just cut the amp out of the circuit and and power them from the deck. It’d give the best sound quality. You could use an aftermarket amp too, but that’d be the most work.
Spudhut
US Navy Submariner
Location
NW Arkansas
Bentonville, AR
Callsign
KG5SPB
I agree with @Mbrooks420, cut out the stock amp and install your own amp of choice. Get a good head unit with good output to power your surrounding speakers.
If you have the factory 8" sub box in the rear passenger panel, there are a few speakers that will fit and the sound is pretty good.
Something I did for my sport - maybe this will help create some ideas.
Gen2 - Simple - Sound System Upgrade
filb
Location
gold coast
04 explorer uz
How do you cut the amp out of the circuit i cant even find it ive been told its in the passenger kick panel drivers side over here it that true?
Mbrooks420
High Voltage.
Its in the rear cargo area behind the right side panel. Are you sure you have an amp? Not all of them do, I don’t think. Do you have a factory sub?
filb
Location
gold coast
04 explorer uz
I dont know if i have a factory amp or a factory sub for sure i will take the panels off today and have a look to be certain
The reason i think i have a factory sub is the stereo im putting in came from my old car and worked fine and the old stereo i took from the ex worked ok but when i pit the new stereo in i get no sound and the old wiring for old stereo was all over the place and pretty much just fell apart so i didnt get to see what went where and have managed to get power and speaker wires sorted but still no sound which is why i think there is a factory amp does this make sense?
Mbrooks420
High Voltage.
You can bypass it at the amp if you don’t want to rewire the speakers.
Mbrooks420
High Voltage.
Yes. Wire the signal inputs to the output side of the wires. If you power the red/blk wire it *might* work. I wouldn’t want to use the factory junk, however.
