Still Bogging | Ford Explorer - Ford Ranger Forums - Serious Explorations
Still Bogging
94expo
Long Beach, Calif
94 XLT
This has been going on for sometime only on long trips. Day to day usage everythings fine. Trips to SanDiego from LA we've got problems. After 40 miles yesterday it started Bogging when and when I kick down the gas pedal at about 3000 RPM it cleared up. then you let up and go back to normal driving and it starts all over. After I got to SanDiego I was there for about 2 hours and the truck was sitting. On the return trip It started at about 90 miles. Samething. I pulled the codes and got the following:
Code: 172 HEGO (heated Exhaust gas oxygen) sensor Voltage signal indicates lean. bank 1.
Code: 173 HEGO sensor voltage indicates rich bank 1 Code: 176 HEGO sensor indicates lean bank 2.
Code: 177 HEGO sensor indicates rich bank 2. And
Code: 335 Pressure feedback EGR (PFE) sensor or EGR pressure transducer (EPT) signal voltage higher or lower than expected. (Key On Engine Off Self Test) This morning I drove 8 Miles to work and Had no problems. Im thinking Maybe a bad Fuel Presure Regulator. Any Ideas.
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
Sounds to me like bad O2 sensors or EGR hardware.
94expo
Long Beach, Calif
94 XLT
Does Bank 1 and Bank 2 sense seperate. If so would'nt it have to be something more common to all 6 cylinders and not just one side of the engine. Since Both O2 sensers are seeing the same problem.
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
Try cleaning your MAS and see if any of your intake manifold bolts are loose.
94expo
Long Beach, Calif
94 XLT
I checked the Bolts and Cleaned the MAF. And it made no differance.
