Ford has tsb for reprogramming pcm for lean or rich codes. This may be your fix.
Printable View (6 KB)
TSB
04-22-11 MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DIAGNOSTIC TROUBLE CODES (DTC'S) P0172, P0175, P0171 AND/OR P0174 - 4.0L SOHC ENGINE - VEHICLES BUILT PRIOR TO 10/4/2004
Publication Date: October 28, 2004
FORD: 2004-2005 Explorer
MERCURY: 2004-2005 Mountaineer
This article supersedes TSB 04-19-7 to update the vehicle model years and DTC information.
ISSUE:
Some 2004-2005 Explorer 4dr/Mountaineer vehicles built prior to 10/4/2004 with the 4.0L SOHC engine, may exhibit the MIL illuminated with one or more of the following DTC's:
P0172 - SYSTEM TOO RICH (BANK 1)
P0175 - SYSTEM TOO RICH (BANK 2)
P0171 - SYSTEM TOO LEAN (BANK 1)
P0174 - SYSTEM TOO LEAN (BANK 2)
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using WDS release B33.10 or higher. Calibration files may also be obtained at
www.motorcraft.com.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
042211A Check For Diagnostic Trouble Codes And Reprogram Powertain Control Module 0.4 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
RECALEM 04
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2004 Ford Motor Company
