Is this constant, like a malfunction? When I had a problem with mine, I located the alarm box, and unplugged one of the connectors to make it stay off for awhile while I worked on it. When I unplugged the second connector the truck wouldn't start- this seems important. Your alarm brain is located in the jack compartment in the drivers side rear q-panel, well forward of the fuel filler. It is a black and white box mounted horizontally with two connectors on it. It's impossible to get at without removing the better part of the trim panel. It has a tag on it that identifies it as the alarm unit, but I was unable to actually see the tag 'till after I had removed it. Unplugging the connector towards the rear of the truck disabled it. Unplugging the forward connector disabled my starter. Good luck!
