stock radio ground 96 | Ford Explorer - Ford Ranger Forums - Serious Explorations
brownbagg
grand bay, al
96 xlt
where would the radio be ground at, my radio acted like it has a bad ground, it work perfect till you hit a bump then it dead. looking for chassis ground screw
Bruces expo
Middle GA
91 Mazda Navajo
I do Believe the stock ground wire is wired into the harness where the other wires are going into the connector to the rear of the head unit . You can try to add a 2nd ground to a piece of metal inside the dash to see if that works , you should be able to find a screw on the stock radio and connect a ring terminal to a wire and ground it in the dash , just a thought .
