Stock Ride Height
2many
Somerset County, New Jersey
1999 XLT AWD SOHC
I have a 1999 SOHC AWD 4 door X and am trying to find out what the stock ride height is supposed to be in the front. Is there a factory ride height measurement from the ground to a framerail, fender lip, etc.?
2many
1999 XLT AWD SOHC
Come on guys...
Robb
There is nothing in concrete. All Explorers varied slightly (with 2nd gens, via t-bar adjustment) in height in how they came from the factory.
mustangGT
charleston S.C.
86 stang (no explorer yet
if i come by one and i have a tape meisure ill meisure it for you :-S likly but posible...
mustangGT
charleston S.C.
explorer info
hey i dunno if these are the years your looking for but it might be of some help..
Josh :exp:
2many
1999 XLT AWD SOHC
bump... ???
surely someone must know the stock ride height measurements to the fender lip.
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
What part of "There is nothing in concrete. All Explorers varied slightly (with 2nd gens, via t-bar adjustment) in height in how they came from the factory." did you not understand? Every truck is different from the factory.
Brian_B
Mountain Home, AR
2000 mounty / 56 f-100
Even if they were all identical from the factory, they would not be now. You drive and the suspension settles, the tires wear, you change brands of tires. Nothing would stay exactly the same.
2many
1999 XLT AWD SOHC
so your theory is that ford sent them out the door at any random setting "set them at whatever height you feel like assembly line guys" right...
just because you don't know what the setting is doesn't mean there isn't one.
dman726749
Greenwood Indiana
96 xlt
yep thats how it works :rolleyes:
2many
1999 XLT AWD SOHC
i am not asking what SHOULD my ride height be after this, that and the other thing. i am asking what was the target when ford screwed them together.
again, just because you don't know...
dman726749
Greenwood Indiana
96 xlt
well your going to need to give more info then such as tire size becasue the explorers came with many diffrent sizes of tires and rims from the factory
Brian_B
Mountain Home, AR
Simple enough. Go ask ford. Otherwise forget it.
dman726749
Greenwood Indiana
96 xlt
ohh dont forget the average temperature in your area as it can also effect the ride height, as well as your weight and how much gas you have in the truck
2many
1999 XLT AWD SOHC
okay, i have 235/75-15's. what's the stock ride height?
Brian_B
Mountain Home, AR
Don't forget the air pressure in the tires either. Shall we continue?
2many
1999 XLT AWD SOHC
sure, feel free if you've got nothing else better to do than post useless replies that lack any information.
2many
1999 XLT AWD SOHC
so much for the resource value of the serious explorations message board. :thumbdwn:
Brian_B
Mountain Home, AR
You were given two options above if you want to pursue this (for some weird reason) contact ford youself and let them tell you there is not one..........or 137cm which is 53.9370079 inches.
I Air Suspension (Stock) Lowered Explorer - Ranger Suspension Tech 2
L added new pics to stock floor explore thread Lowered Explorer - Ranger Suspension Tech 0
L Stock floored xploder Lowered Explorer - Ranger Suspension Tech 28
D Rear drop: stock spacers Lowered Explorer - Ranger Suspension Tech 3
J Need pics of lowered 2k2/3 on stock wheels Lowered Explorer - Ranger Suspension Tech 4
9 1998 Stock front swaybar diameter? Lowered Explorer - Ranger Suspension Tech 4
M Lowering 2000 Limited with rear air supension - Ride Height Calibration Question Lowered Explorer - Ranger Suspension Tech 0
F 2008 Sport Trac Adrenalin air ride Lowered Explorer - Ranger Suspension Tech 4
S Cutting Air Ride parts on the cnc Lowered Explorer - Ranger Suspension Tech 3
R Air Ride on a 00 AWD? Lowered Explorer - Ranger Suspension Tech 6
W Noob - needs air ride help Lowered Explorer - Ranger Suspension Tech 6
N Bouncy ride ove speed bumps . . help Lowered Explorer - Ranger Suspension Tech 8
I air ride questions Lowered Explorer - Ranger Suspension Tech 1
T EE lowering blocks? and unstable ride Lowered Explorer - Ranger Suspension Tech 4
J X Sport (mono leafs) and lowering ride quality with rearend sag? Lowered Explorer - Ranger Suspension Tech 5
D ride quality in a lowered X Lowered Explorer - Ranger Suspension Tech 17
X lowest possible height with 20s(pics) Lowered Explorer - Ranger Suspension Tech 15
