mark3901
- October 21, 2014
- Glen Burnie, MD
- 2001 Explorer XLT 4x4
This one had me stumped for awhile...
My 2001 4D XLT 4x4 with the larger factory 16" wheels and 255/75/16 tire size was making some horrible sounds when turning about halfway to the right while moving in reverse since I bought it. PO had bought new, no front damage whatsoever in the life of the truck from him or I.
After replacing diff fluid and transfer case fluid (common answers to the symptoms I had) the problem persisted as bad as ever. Finally had someone get right next to the tire and watch over and over. Turned out the correct factory sized tires and wheels were contacting the lower bumper slightly on the driver's side causing a loud vibrating (almost grinding sound) as it skipped over the treads.
Best I can figure without exact specs is that the Kelly Safari ATR tires I put on in replacement of old OEM Wranglers had a slightly more aggressive tread which caused the rub and gut wrenching sounds. 20 minutes and a few washers from Home Depot and I shimmed the bumper out a few millimeters and voila it was fixed. May help anyone else stumped by a similar situation.
