Strange Noise
golthem
2006 Ford Explorer EB
Hey folks! I have been dealing with an issue over the past couple of months and hope maybe someone here will be able to help me out. I like being able to work on the car myself, but I am new to it and do not have the experience many of you do, so I am hoping you might be able to help me out.
I have a 2006 Eddie Bauer edition that is just about to hit 130,000. I have been having a strange grating noise that seems to come from the driver's side of the vehicle and more toward the center front. It starts as a low grating as I begin to accelerate but then quickly turns into a fast high pitched grating noise. Once I get below 20 MPH it stops. The vehicle can be difficult to get up to speed, it just drags a little bit more than normal, and my gas mileage has gone down quite a bit.
A mechanic friend initially recommended replacing the u-joint to the front driveshaft which helped boost my gas mileage from 11 MPG to 12 MPG, but I still have the noise.
Any thoughts or things you might recommend checking?
Littleant
Location
Vermont
Orleans
2010 Mountaineer 4.0
Front differential. Check the fluid first. Does it make any noise at startup. If it does possible timing chain. But leaning towards Front differential. Other's will chime in.
94Eddie
2010 Mountaineer Premier
The best way to target the source of the noise is to put the vehicle on a lift with the wheels free and run it to cause the noise to appear. This would also allow easy access to check for wheel bearing problems and easily inspect other components. Also, if you are seeing a significant MPG drop due to a drive train issue then the failing component should be hotter than it normally would run. The energy consumed by the drive train component would most like be dissipated as heat generated from added friction. Checking various drive train items with a laser thermometer could be a way to identify where a problem component might be. Checking the rear differential temperature against the front differential temperature after a drive might show if their is a problem in the front differential.
S Strange "whale moaning" type noise from driver's rear area. Stock 2006 -2010 Explorers 4
G Rear Air strange noise on 2010 V8 4x4 Stock 2006 -2010 Explorers 2
N Question on Strange "road noise" from left front Stock 2006 -2010 Explorers 6
C Strange whining noise from Transmission Stock 2006 -2010 Explorers 2
P Strange Engine Noise 08 Explorer 4.0L V6 SOHC Stock 2006 -2010 Explorers 9
L Strange, subtle noise Stock 2006 -2010 Explorers 2
T Strange noise coming from rear speakers? Stock 2006 -2010 Explorers 2
F Strange ticking noise??? Took a youtube video to show it Stock 2006 -2010 Explorers 19
R 06 - Strange "Venting" Noise from Trunk Stock 2006 -2010 Explorers 8
E Weak Blower and Strange Smell From the Vents Stock 2006 -2010 Explorers 0
A strange Sound when put the key at On Position Stock 2006 -2010 Explorers 33
T Strange Transmission Issue Stock 2006 -2010 Explorers 11
S Found a strange cause for the P0403, P0443 codes Stock 2006 -2010 Explorers 7
M Strange starting sometimes Stock 2006 -2010 Explorers 6
S Strange switch in the car Stock 2006 -2010 Explorers 7
R Strange Symbol Stock 2006 -2010 Explorers 5
A strange issue with 07 V8, no diagnostic lights Stock 2006 -2010 Explorers 11
BigNutz Strange Question Stock 2006 -2010 Explorers 1
D Strange humming/vibration Stock 2006 -2010 Explorers 9
E climate control acting strange Stock 2006 -2010 Explorers 5
T strange whining sound please help Stock 2006 -2010 Explorers 5
Y Strange strange acceleration problem Stock 2006 -2010 Explorers 9
C '06 Eddie Bauer - Strange Electrical Problem Stock 2006 -2010 Explorers 29
A Strange noises at highway speed Stock 2006 -2010 Explorers 7
M Strange Smell from the AC Stock 2006 -2010 Explorers 2
T bad bearing like noise in front Stock 2006 -2010 Explorers 7
I Humming or Roaring Noise Gets Louder with Speed Solved Stock 2006 -2010 Explorers 2
M Front Wheel/Axle Noise Stock 2006 -2010 Explorers 5
L Can't find where the noise comes from Stock 2006 -2010 Explorers 2
D Noise from factory headunit Stock 2006 -2010 Explorers 2
P Knocking noise 4.6 3v Stock 2006 -2010 Explorers 11
H 08 mercury mountaineer front end noise Stock 2006 -2010 Explorers 5
M 2010 Mountaineer noise coming from Driver Front Wheel under braking Stock 2006 -2010 Explorers 9
V Popping noise from front end? Stock 2006 -2010 Explorers 1
J Clink noise from front end Stock 2006 -2010 Explorers 2
K Osilating "thruming" noise in turns. Stock 2006 -2010 Explorers 6
S Noise when Accelerating. Stock 2006 -2010 Explorers 1
S Noise when slowing down Stock 2006 -2010 Explorers 4
J 2006 4.6L V8 XLT whining noise Stock 2006 -2010 Explorers 1
B Rhythmic noise coming from rear driver side Stock 2006 -2010 Explorers 7
S 2006 4.0 Timing Chain Noise? Stock 2006 -2010 Explorers 10
W 2007 Explorer grinding noise Stock 2006 -2010 Explorers 3
S '07 A/C makes a intermittent groaning/howling noise Stock 2006 -2010 Explorers 1
P 08 Ltd 4.6L Front drive line buzzing noise/vibration Stock 2006 -2010 Explorers 6
P 08 4.6L engine ticking noise under load. Stock 2006 -2010 Explorers 10
M 2008 Exp Vibration/Noise??? Stock 2006 -2010 Explorers 10
F 06 4.0 noise. Stock 2006 -2010 Explorers 41
H Minor whining noise from rear? Stock 2006 -2010 Explorers 3
J Air flow noise 07 Mountaineer Stock 2006 -2010 Explorers 5
Dre 06 Mounty, front end noise Stock 2006 -2010 Explorers 2
Similar threads
