MNBen
- February 11, 2011
- Cosmos, MN
- 99 Ranger 4x4 XLT Ext. Ca
1999 Ranger 4x4 XLT Extended cab 4.0 with '03 engine, wire harness, ignition, and PCM.
Since the previous owner put in the '03 wire harness he did not hook up the old horn which is in the front driver corner behind the headlight. But I cannot find any wire in that area what so ever to hook the the horn. I did find a wire/plug that goes nowhere behind the front passenger headlight. The plug is blue. If you have an '03 ranger could you check at where your horn is and if possible what the plug I mentioned is for below is a picture.
Thanks,
MNBen
Thanks,
MNBen
