stripped security torx(maf) | Ford Explorer - Ford Ranger Forums - Serious Explorations
thewishkah
Brooklyn New York
1994 explorer xlt
Ok recently my cone filter came off my intake and was like that for I dont know how long. I put it back on but my gas mileage is horrible 6.8 mpg(thinking maybe the mafs got pretty dirty) when I went to take it out to clean it the security torx screw head was a little stripped and is now completly stripped.
My question is how do I go about getting it out to clean my MAFS. I thought about taking a small saw, or a dremel to the head so I can use a flat head screw driver but being it is the mafs I dont want to use anything that might break the filament since they are expensive.
Any help is much apreciated , with gas prices the way they are I need to atleast try and see if I get any results out of cleaning it.
thanks for the help.
Jon
Chew_12
Working
Chandler, AZ
'93 XLT
I dremeled my and it worked great.
baddawg
Ottawa, Ontario
1991 Explorer XL 2WD
Last night I took my MAF out. I used a small screw driver and bent the pin in the security torx screw over back and forth a few times and it snaped out allowing me to use a T20 torx to remove the screws.
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
6.8 mpg <- erp!!
alexefron
Rochester, NY
93 XLT
I hacksawed mine into a flathead screw, works great. I used one of the hacksaws thats just a little handle with the blade sticking out of the end. It took a little work, but i had it done pretty quick
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
vice grips can get that sucker loose. replace it with a normal screw
or dremmel it into a flathead.
spindlecone
San Jose, Calif
2003 sport trac
Those screws can be a real bitc* :D
Robb
Why do you need to remove the actual sensor from the housing? You can clean it with it still on there.
MONMIX
I fix dents
Moderator Emeritus
Millersville , Maryland
2000 Explorer Sport
Left handed drill bits are gods gift to the earth.
Love the photo Spindle
Brian_B
Mountain Home, AR
2000 mounty / 56 f-100
I think spindlecone needs a larger pipe wrench. That one seems a bit small for the screw he is trying to remove. :D
spindlecone
San Jose, Calif
2003 sport trac
got her done with a come along tied to a big tree, hella job:)
trucku
Queens, New York and living in Budd Lake, NJ now.
2002 Explorer XLS 4.0 4x4
HA HA! attach a winch to the MAF housing and you might have a chance to get it off.
Cleaned my MAF right in the housing. I don't think you need to separate it from it. Also lessons chance of you damaging it.
thewishkah
Brooklyn New York
1994 explorer xlt
izwack what do you mean erp?, love the pics spindlecone and how would I go about cleaning it in the housing?
DeRocha
NEX Vice President
Moderator Emeritus
Brockton, MA
'93 XLT 4x4
Hey Spindlecone is that the new Leatherman model ? :D
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
ERP as in its unbelievable!
gavin
Anchorage, Alaska
'97 Explorer XLT AWD 5.0L
remove whole MAF housing, spray electrical cleaner on the wire sensor, let dry, reinstall.
thewishkah
Brooklyn New York
1994 explorer xlt
Well in my mission to clean maf I broke my heater temp control?(black plastic with a metal pressure release) the thing was wrotted badly so I bought a new one and put it in. so I got looking for other issues and found a vacum hose was disconected by the top left of the engine (alittle hard to get to with big hands).
I put the hose back on the tree it came off of and my idle dropped like 2-300 and idles smoothly no more eratic idle. Could this of contributed to my poor gas milage? thanks again for all the help. Now with a clean mafs, a filter that wont fall off again and the vacum leak fixed maybe i can get DECENT milage lol.
Skibum1989
Sammamish, WA
'95 XLT
Cool, be sure to keep us updated on your MPG.
I'm gonna do this tomorrow, do I need to remove the sensor from the MAF housing or not to do the cleaing? I've heard mixed things. I really don't wanna break anything trying to get those torx screws off. I'd much rather just take the housing off my intake, disconnect the electrical connection and use the cleaner directly on the wires without the swearing and cussing associated with the torx. Also, is This a good cleaner to use?
